Members: 17,542
Threads: 32,283
Total Online: 467
Newest Member: clara5174
Old December 19th, 2009, 04:27 AM   #1
bugroadster
bugroadster's Avatar
Default Body kit
Re:: roadster panels
Ok its time to fasten the right front fiberglass panel to the right front on the heb the question is how do all you members fasrten your glass to the steel
Old December 19th, 2009, 04:51 AM   #2
carlbugs
carlbugs's Avatar
Default Re: Body kit
3M 5200
ACHTUNG!!
Das machine is nicht fur gerfingerpoken und mittengraben!
Is too easy schnappen der springenwerk und blowenfusen und poppencorken mit spitzensparken!
Ist nicht fur gerwerken by das dumkopfen das rubbernecken sightseeren!
Keepen der hands in der pockets!
Relaxen und watch all der blinkenlights!
carlbugs is offline   Reply With Quote
Old December 19th, 2009, 04:58 AM   #3
epoxy
Old December 19th, 2009, 05:14 AM   #4
Panel bond? Don't know if that's the correct name but 401-Resto Tim used it to repair the hood on the turbo bug and an inner wheel well patch. The shit is bomb proof.
Old December 19th, 2009, 08:30 AM   #5
http://www.shop3m.com/3m-automix-pan...vc2pjz33g.html
http://www.lord.com/Home/ProductsSer...0/Default.aspx
Old December 19th, 2009, 01:16 PM   #6
bugroadster
I have a 3m gun so i will probably use that the lord fusor i have a gun but had trouble with the product a van roof blew off and they wouldnt stand behind there product
Old December 19th, 2009, 03:55 PM   #7
Well if parts are blowing off i wouldn't stand there either.
Use some mechanical fasteners as well. Pop rivets will do the trick.
You gotta have the right temps, clean rough surface....
I like 3M 5200 personally, but theres some other good prouct out there. Lords has some as well as Dura.
