Members: 17,688
Threads: 32,298
Total Online: 80
Newest Member: gstong
- by Frank3
Old December 23rd, 2009, 04:59 AM   #1
KdFmangler
KdFmangler's Avatar
Default crotch coolers just make them
Re:: why buy originals
i ahve been wanting crotch coolers on the mangler for a while now and i have been watching the prices on the samba . now i know you can buy new or get some crusty old pieces but i finaly decided to just bite the bullet and make a set . they really are not to hard to make . i started buy making a cardboard templet for the door size . then i got two pieces of wood . i used the templet and marked around one piece of wood. i made sure that the edges were sanded and streight . then i took that piece of wood and nailed it to the other . i thend used a grinder to shape the top piece of wood (that had the opening for the door in it) to the contour of the body. now i cut a piece of metal that was bigger than the opening for the dooor by at least 1 1/4 . now i fastened the metal to my buck. now start shaping it to the buck. i took about two hours total to shape it , then cut out the center and made the connector ( 3 1/8 wide)to go from the door to the inside of the body. then i made a door . i will leave you one your own on the hinge . this part was alittle tricky. these are not totaly authentic but close enough. here are some photos
My PhotoBucket Pics
https://www.facebook.com/pages/Hotro...18525414956399
never arque with an idiot. they lower you to there standards and beat you with experence!
http://www.droppedaxleproductions.co.../DAPindex.html
KdFmangler is offline   Reply With Quote
Old December 23rd, 2009, 05:04 AM   #2
PJLOval
PJLOval's Avatar
Default Re: crotch coolers just make them
I want to make a set for my project. Thanks for the post!
PJLOval is online now   Reply With Quote
Old December 23rd, 2009, 05:05 AM   #3
purplepeopleeater
purplepeopleeater's Avatar
Looks good.
purplepeopleeater is offline   Reply With Quote
Old December 23rd, 2009, 05:11 AM   #4
Looks good!
Old December 23rd, 2009, 07:13 AM   #5
cdscowboy
cdscowboy's Avatar
Nicely done! How's it gonna open?
1970 T1
Build
www.99westcustoms.com
Old December 23rd, 2009, 07:19 AM   #6
ClassicGMJunkie
ClassicGMJunkie's Avatar
when it reaches 86 mph.
62 Impala 2dr HT build
70 Cabrio build
Intro thread
Old December 23rd, 2009, 09:18 AM   #7
DirtGhost
DirtGhost's Avatar
is that forward or backwards ?
DirtGhost is offline   Reply With Quote
Old December 23rd, 2009, 09:25 AM   #8
ClassicGMJunkie
looks like if installed forwards. seriously tho, that does present itself with a mild boggle.
70 Cabrio build
Intro thread
Old December 23rd, 2009, 09:40 AM   #9
KdFmangler
KdFmangler's Avatar
its mounted just like vw did . forward and open just like vw did . on the opening device . it is hinged but i hva enot made a handle or anything to keep it shut or open yet . more to come
My PhotoBucket Pics
Old December 23rd, 2009, 12:31 PM   #10
Jogyver
Jogyver's Avatar
Kd , Nice work! Can you post some pictures of the hinges and the interior mount?
Old December 23rd, 2009, 01:10 PM   #11
ratlook63
ratlook63's Avatar
Wasnt Hebster 52 making a set of these awhile back? I know its been done before. I tried a search, but I cant find it. Either way, KDF if you want any detail pics of an OG set shoot me a PM.
Wanted:
Split tail lights. Repop ok!
My Band
Old December 23rd, 2009, 01:17 PM   #12
How does the original ducting work on the inside ?
Or is there any ?
Old December 23rd, 2009, 01:19 PM   #13
Yes please!!!
Old December 23rd, 2009, 01:46 PM   #14
ratlook63
ratlook63's Avatar
Its dark out now.... I'll try in the AM. Any particular spots?
Wanted:
My Band
Old December 23rd, 2009, 02:08 PM   #15
Anything that shows the ducting, controls and what the vents look like inside the car.
Old December 23rd, 2009, 02:45 PM   #16
ratlook63
ratlook63's Avatar
Can do, whoever had the thread before had dimentions with pics as well.
Here is an old pic from my photo bucket, shows the inside
http://i383.photobucket.com/albums/o...ok63/vw017.jpg
http://s383.photobucket.com/albums/o...rent=vw006.jpg
http://i383.photobucket.com/albums/o.../1-5-08180.jpg
Wanted:
My Band
Old December 23rd, 2009, 03:41 PM   #17
Jogyver
Jogyver's Avatar
Here's a few ealier threads
http://www.volksrods.com/forum/showthread.php?t=27386
Old December 23rd, 2009, 07:05 PM   #18
Looks good.
I had a thought though, if you were to press these or stamp them it might go alot faster and easier. Betcha if you drilled holes in the center where you cut them out and used long bolts you could simply tighten them up and it would press your shapes in.
Old December 23rd, 2009, 10:03 PM   #19
tool2
tool2's Avatar
Please keep us posted on that. that looks awsome
tool2 is offline   Reply With Quote
Old December 24th, 2009, 01:39 AM   #20
Boes
Boes's Avatar
can not wait for the final result to see!
keep on posting
Old December 24th, 2009, 03:07 AM   #21
STUKA
STUKA's Avatar
I was thinking the same thing too Jon. Possibly rigged up in a Bearing Press.
Nice work Kd, esp the strainer thing on the door.
STUKA is offline   Reply With Quote
Old December 24th, 2009, 04:37 AM   #22
KdFmangler
KdFmangler's Avatar
you could make a die and press them . i used heavier 16ga metah to make mine . the front quarters on my car were not in the best shape and the metal was not that good so i cheated and made the opening thicker for something to weld to. i will post more photos later as i finish the hanle to open it.
My PhotoBucket Pics
Old December 24th, 2009, 10:37 AM   #23
notched
notched's Avatar
Very NICE!
Phillip Bradfield
Old December 24th, 2009, 01:08 PM   #24
ratlook63
ratlook63's Avatar
Some pics of mine
http://s383.photobucket.com/albums/oo278/ratlook63/
Wanted:
My Band
Old December 24th, 2009, 02:57 PM   #25
KdFmangler
KdFmangler's Avatar
thanks for the photos ratlook63 . i was not sure totaly what the inside looked like . looks like i need to made a deflector.
My PhotoBucket Pics
crotch coolers
