Threads: 32,402
Total Online: 625
- by marnat3
Old February 24th, 2010, 10:38 PM   #1
GlowstickNinja
GlowstickNinja's Avatar
Default Beam Extender Install Walkthrough
Alright Figured I would post my pics and give a detailed description of how to install a dbug41 beam extender. This is a balljoint-balljoint extender. If you are doing a linkpin suspension install may be different.
You will Need:
A socket set
1/2", 4" long grade 8 bolts x 4 $1.84each Home depot
1/2", grade 8 nuts x 4 $0.50each Home depot
1/2", thick washers x 8 $0.88/3 in bag Home depot
1/2", thick split washers x 4 $0.38each Home Depot
Red Loctite approx $5.49 for a tube.
first loosen tie rods from steering box.
jack up the frame or the car and now remove tires.
Next loosen and remove four bolts holding front beam onto pan. Caution beam will fall, so make sure you have a jack/or support of some kind under the beam as it is heavy. I used a tire.
This is what it should look like without the beam attached.
Now bolt your extender to the pan. you will use the bolts that came out of the beam originally.
Now get your bolts ready to bolt the beam to the extender. Bolts should be mounted as follows, starting from top of bolt to nut. Bolt, Split washer, thick washer, through beam and extender, thick washer, and then the nut. I also recommend threading with Red Loctite so the for sure won't move. Once bolted up it should look like this.......(Note: it's easier to put bottom half of beam into extender first then rock it up into the top part of the extender)
now all that is left to do is put the tires back on, bolt the tie rods back onto the steering box, and reconnect your steering damper. should look like this......
All finished. I think I'm in love hahahaha
GlowstickNinja is offline   Reply With Quote
Old February 25th, 2010, 05:22 AM   #2
Default Re: Beam Extender Install Walkthrough
looks great and nice simple tech!
so who painted it ? you or Doug?
cuz I heart puuurrrple~~~~
(and yes, this will go tech bin, later:)
Old February 25th, 2010, 06:43 AM   #3
Originally Posted by GlowstickNinja View Post
You will Need:
A socket set
Old February 25th, 2010, 08:33 AM   #4
Please continue, with how to connect the steering.
Old February 25th, 2010, 09:47 AM   #5
GlowstickNinja
I painted this one. I used a high temp engine ceramic and baked it in the oven for 40 mins at 200 Fahrenheit. The color is actually much darker, I think because it is glossy it comes out this barney purple color, when actually it is a dark plum.
yes I definitely will. My supplies should be here next week maybe a little later. I will update the install for sure.
Old February 25th, 2010, 10:03 AM   #6
and with how you are going to brace the framehead....
you are going to brace the framehead, right?
Old February 25th, 2010, 11:02 AM   #7
GlowstickNinja
Yes the framehead will be braced for sure. Will post as soon as I get the materials to do so. Thanks guys!
Old February 25th, 2010, 01:45 PM   #8
I like how you got EVERYTHING unnecessary out of the way for the pics!
Easy peasy!!
I imagine it's a little hard to show bracing when there's nothing there to brace it to.
Old February 25th, 2010, 01:49 PM   #9
GlowstickNinja
Easy peasy!!
Hahaha yeah if you saw the rust bucket this frame came out of you would cringe!
Old February 25th, 2010, 01:59 PM   #10
Believe me, Been there, done that more than once!
Old February 25th, 2010, 02:37 PM   #11
lordboxboy
lordboxboy's Avatar
when you say "split washers" do you mean lock washers??
lordboxboy is offline   Reply With Quote
Old February 25th, 2010, 03:41 PM   #12
GlowstickNinja
Yes, some call them that as well.
Old February 25th, 2010, 03:43 PM   #13
AirheadZim
AirheadZim's Avatar
Hey Gllowstick.....THANKS!!!! you deserve a HUGE round of applause from us who have not done this yet but plan to. (subscribing to this thread).
Old February 25th, 2010, 06:26 PM   #14
Rhyno
Rhyno's Avatar
Great write up It kinda takes out the fear of doing it,being the front of the car and all,Kinda.Keep us updated.
Rhyno is offline   Reply With Quote
Old February 25th, 2010, 06:56 PM   #15
GlowstickNinja
Hey thanks man. It was very simple. Obviously if you dont have the body off the car it could be a bit harder, but covers the basics for sure. I will be doing the steering soon and same thing it should be very easy setup. I will continue the original post in easy to understand steps.
Old February 25th, 2010, 07:10 PM   #16
Dbug41
Dbug41's Avatar
Very well done sir
outstanding! carry on.
life is short make fun of it!
Old February 25th, 2010, 10:04 PM   #17
rodderdan
The lock washer goes behind the nut to lock it place,not the bolt head.
Old February 25th, 2010, 10:15 PM   #18
GlowstickNinja
hmmm, I don't know for sure. However multiple items that I have either taken apart or put together called for the split washer under the top of the head of the bolt.
This makes sense from a moment of inertia stand point. The moment will be imposed when a force is applied to the length of the bolt concentrating at the head of the bolt. I could be wrong but the shear mechanics work out for it under the bolt head.
From a bite in type of observation it makes sense under the nut, so that it will "bite in" when the nut loosens.
NASA engineers consider them garbage.......I think it is more of opinion than anything. You would probably be fine with just red loctite.
Old February 26th, 2010, 01:42 AM   #19
Bugratt
Bugratt's Avatar
Great job on the install!! I did mine with the body on. Not much harder. Helps to have a friend or 2 handy though...lol. Someone has to make sure no one spills the beers...lol. Dbug makes some great stuff!! I own 2 of the 10" extenders. Keep up the good work GlowstickNinja!! You too Doug!! Don't forget to check out Doug's other great stuff.
I'm not listening to the voices in my head...lol. Did you hear that?...lol
Bugratt is offline   Reply With Quote
Old February 26th, 2010, 10:05 AM   #20
X2 on the lock washer going under the NUT & NOT under the BOLT...
Old February 26th, 2010, 10:57 AM   #21
Damn........ I thought you said "SPIT WASHERS"............ I couldn't finish my install because my mouth went dry
Old February 26th, 2010, 11:47 AM   #22
GlowstickNinja
Better grab another beer!
Old June 1st, 2010, 08:28 AM   #23
cliff h
cliff h's Avatar
Any more updates?
cliff h is offline   Reply With Quote
Old June 1st, 2010, 08:41 AM   #24
Hmm he hasn't been on since April 25th,2010.
This can't be moved to tech bin unfinished guys~
Someone want to finish this? Can't build the tech bin with dead threads like this.
Cliff, check the thread by dbug41, might find more answers there.
Old August 20th, 2011, 12:56 AM   #25
Poomwah
I know this is an OLD thread, but I'm going to be getting one of these late next month, want me to continue the thread for the sake of the tech bin?
Poomwah is offline   Reply With Quote
beam extender, extender
