Members: 17,510
Threads: 32,311
Total Online: 434
Newest Member: donzimatt
- by Zee
Old May 12th, 2011, 08:21 AM   #26
psychopork
psychopork's Avatar
Default Re: Project ....Schleppen ass
love the cab man looks great. couldn't tell it doesn't belong
Thanx psycopiglet,
Old May 12th, 2011, 10:13 AM   #27
Lostrebel
Thanks TJM ....I'm not sure what it is sitting at right now I still am not done with the front and rear end but when they are done it will be set at 3 degrees Positive (the front higher than the back) and that will be at ride height You really want to set it up once the car has all the tires and weight it will have when driving and keep in mind most intakes where the carb sits have a 3 degree negative angle to them so if your checking the angle on the carb mounting surface it should be level with all that said I have seen thousands of street and hot rods where the engine has sat at much more of an angle and they where fine.....
Thanks Psychopork.....Where abouts in Georgia are you?
Lostrebel is offline   Reply With Quote
Old May 12th, 2011, 12:13 PM   #28
psychopork
psychopork's Avatar
Pooler, GA. (15 minutes north of savannah) movin to Waldorf, Maryland before fall
Thanx psycopiglet,
Old November 4th, 2011, 10:09 AM   #29
markh
markh's Avatar
Any updates on the truck?
Old November 4th, 2011, 11:01 AM   #30
crack monkey
crack monkey's Avatar
I wish the top corners of the doors were rounded to flow better but it reply looks good
Old November 4th, 2011, 06:39 PM   #31
yellowbug1966
yellowbug1966's Avatar
agree on the door corners. other than that its killer id like to see pics on that front clip tilting..and how you hinged it .
yellowbug1966 is offline   Reply With Quote
Old January 2nd, 2012, 06:18 AM   #32
Lostrebel
I haven't got much done on it lately been busy working on my sisters house....I agree the door corners have been bugging me since I did it and they will be rounded .....I did get some seats for it out of a 79 dodge motor home that fit it perfectly besides they look like they are out of a 70's barroom I have to dye them ....The nose is going to have pins on the nose side and a bearing on each frame side right now it just has a bolt through the nose and the chassis on each side works great but I'm gonna put the bearings anyways....My New years resolution is to get back working on it...lol
Old January 2nd, 2012, 07:01 AM   #33
Lostrebel
Seat pics
Old September 13th, 2017, 07:46 PM   #34
Lostrebel
[IMG][/IMG]Been a while it's been on the back burner but still got it and work on it here and there
Old September 13th, 2017, 07:50 PM   #35
She's looking cool. Cab is fantastic.
Old September 13th, 2017, 08:05 PM   #36
Lostrebel
Thanks it's getting there very slowly though....lol
Old September 13th, 2017, 09:42 PM   #37
Yup, but you make some of us look like our progress is just flying along.
Old September 14th, 2017, 06:58 AM   #38
kustomkreep86
kustomkreep86's Avatar
This project rules! Good work on that cab. Definitely super clean.
Build...Break...Fix...Repeat
Old September 14th, 2017, 07:23 AM   #39
Lostrebel
Thanks
Old September 14th, 2017, 07:24 AM   #40
Lostrebel
Straight front axle is a narrowed Model A axle
Old October 22nd, 2017, 02:53 PM   #41
Lostrebel
Re-doing the bed I made for it didn't like no holes and the angled top sides ......
front engine, v8
