Members: 17,343
Threads: 32,253
Total Online: 505
Newest Member: adnan
- by AMMO22
Old May 20th, 2011, 10:09 PM   #1
okyredneck
okyredneck's Avatar
Default Painting Galvanized Steel???
Re:: Is there a home-based method?
I am considering a galvanized steel trailer box purchase from Harbor Freight to use on the FlatBug as a future bed when it becomes an RPU.
I have researched and popular opinion says that short of an acid dip bath there is no way to get paint to stick to it.
I would like to know if there are any somewhat economical methods that I can do at home? Or maybe having it sand-blasted? Perhaps a special primer?
Any secret tips out there? Inquiring minds want/need to know??
The FlatBug build:
http://www.volksrods.com/forum/showthread.php?t=33175
Yes, finally some significant progress(I think).
Redneck
okyredneck is offline   Reply With Quote
Old May 21st, 2011, 02:04 AM   #2
Default Re: Painting Galvanized Steel???
If you can find it, twin etching primer. Comes in a dull mustard yellow or a faded pea soup green.
Old May 21st, 2011, 05:52 AM   #3
flames2go
flames2go's Avatar
I used this stuff a couple of years ago on fence posts that were galvanized: Plasti-Kote 21850G Galvanized Metal Primer. Painted 12 posts after using a self etch prep like prepsol, Urthaned them in black base coat/clear coat, it is still holding up with no chips, flaking etc. The other thing I remember is it depends on how old the galvanize is, the older it is the harder it is to have primer/paint to stick.
A friend near by has a galvanized trailer and he used POR-15 primer then POR-15 high UV finish, it appears to be holding up as well.
If you think you have enough horsepower, think again, there's never enough!
flames2go is offline   Reply With Quote
Old May 21st, 2011, 06:43 AM   #4
58lolight
58lolight's Avatar
Wipe the entire surface with MEK or Acetone. Once you break the Galvanizing coating your paint will stick!
Rich
58lolight is offline   Reply With Quote
Old May 21st, 2011, 10:00 AM   #5
spray it down with lemon juice,rince with clear water and then paint W/ rustoleium. it will stick, look good & be cheap
Old May 21st, 2011, 02:02 PM   #6
okyredneck
okyredneck's Avatar
Thanks for all the really great info & tips y'all, but it looks to be a moot issue for me. Can't find the box kit on the Harbor-Freight site now. Originally seen approx. 4/6 months ago. Must have been dropped.
Redneck
Old May 22nd, 2011, 06:58 PM   #7
1stratrodvw
vinegar
1stratrodvw is offline   Reply With Quote
Old May 22nd, 2011, 07:34 PM   #8
Dbug41
Dbug41's Avatar
Originally Posted by 1stratrodvw View Post
vinegar
x2
BEAM EXTENDERS 101 THE BASICS
Give me a like on facebook
life is short make fun of it!
Old May 23rd, 2011, 07:27 AM   #9
gt brain
gt brain's Avatar
x3 vinegar.
gt brain is offline   Reply With Quote
Old May 26th, 2011, 07:02 AM   #10
V8SuperBeetle
V8SuperBeetle's Avatar
x4 on the vinegar. The sheet metal I used in my engine bay, radiator area, and my trans / driveshaft tunnel is made out of galv. steel. No problems with paint sticking whatsoever.
- Wilson "Billy" Chevalier
galvanized metal
