| Stuff to check out... |
| Forum Stats |
Members: 14,546
Threads: 30,733
Total Online: 50
Newest Member: danyvolks_67
May 18th, 2012, 01:09 AM
#76
Re: DD's 63
In the way back days when clear was thick, we used 200. These days it's thinner so depending on the clear 320 or higher.
Should be able to find out thru a manufacturer's site?
May 18th, 2012, 09:41 AM
#77
Re: DD's 63
I have tried 4 manufacturer's data sheets and they all come up blank for reasons unknown to me....... I'll figure it out one way or another..... usually from trial and error.
May 18th, 2012, 09:56 AM
#78
Re: DD's 63
Ok, so what brand are you using? Maybe someone here has used it and has an idea?
May 18th, 2012, 10:53 AM
#79
Re: DD's 63
Either dupont or Sherwin Williams, depending on local availability. I don't want to use too fine of grit and have it NOT stick or too coarse and show the scratches.
May 18th, 2012, 05:45 PM
#80
Re: DD's 63
Originally Posted by Double D
 none? What kind of paint is it and why would you think you sand before clear coat? If there are areas that need touching up then nib them with 600 and dust some paint over it again before clear coat. The only reason you would sand it before painting was if it was a solvent cured paint (ie. 2k clear). If it is just a laquer base then it will "melt" when hit with clear coat and all blend together.
May 18th, 2012, 07:35 PM
#81
Re: DD's 63
My color coat is Acrylic Laquer primer, Red Oxide, so what I'm understanding is spray on the clear and I'm good to go?
May 18th, 2012, 07:49 PM
#82
Re: DD's 63
Yes sir, if you're really worried about it sticking use a grey or blue scotch brite pad on it before clear coat, personally I wouldnt in fear of having it show through the clear.
May 18th, 2012, 08:24 PM
#83
Re: DD's 63
Thank you, I haven't ever used a clear before, there fore my ignorance about it.
May 22nd, 2012, 05:16 PM
#84
Re: DD's 63
May 30th, 2012, 09:11 PM
#85
Re: DD's 63
May 31st, 2012, 11:07 AM
#86
Re: DD's 63
nice, in the same boat I am today, gotta refurb some old headlights.... your lucky though because you got the internal blinker.... I got to figure out where to put one :(
Gotta ask, even though I may just recive a "  " Whats the final paint gonna look like? color/design?
May 31st, 2012, 12:22 PM
#87
Re: DD's 63
The internal signal is something I installed into the assembly, they didn't come with them. The color scheme is the Red Oxide primer with a flat clear coat. I might put some scallops on it but not sure yet.
June 20th, 2012, 12:17 AM
#88
Re: DD's 63
June 21st, 2012, 07:06 PM
#89
Re: DD's 63
June 21st, 2012, 07:12 PM
#90
Re: DD's 63
I'm going to slap the tired but running 1600 back together and sell it. hopefully I can get enough money out of it to pay for some machine work.
June 21st, 2012, 09:27 PM
#91
Re: DD's 63
Hey D,
I am coming through Barstow on the 28th. If I know some of the parts that you are looking for this build, and I have them, maybe we can meet up and you can help me clean my garage a bit.
Originally Posted by Unkl Ian
June 22nd, 2012, 06:25 PM
#92
Re: DD's 63
Thank you very much for that offer Keith. I'm booked all week with a tile job and I have to get it done by the 28th so we can leave for montana on the 29th. My best option for the moment is selling the engine I had in the car (I know it runs), but for how long in the desert heat??  When I get back from Montana I'll take the two cases and the two pairs of DP heads I have to the machine shop and get everything hot tanked and measured and go from there.
June 22nd, 2012, 11:57 PM
#93
Re: DD's 63
Dang! I was hoping we could meet in person! Sounds like your vacation time is the same as mine. I am leaving here the 28th to get to San Fran on the 29th to spend some time with my Dad. I return on the 10th. Have fun in Montana, and enjoy a break from the desert!
August 29th, 2012, 09:46 PM
#94
Re: DD's 63
Two hours ago I sealed the deal on an abandoned 71 SB project with the roof cut off and a solid drive train. I had been pestering the owner for a month and tonight she called and said I could have it.
I'm really thinking about converting my 63 to IRS. I will have all of the parts for the swap, I'll only have to weld in the inner pivot mounts for the trailing arms. Hopefully this score will solve my engine woes as well!!
August 29th, 2012, 10:32 PM
#95
Re: DD's 63
D!
Congrats! Just welding in the inner pivots is sort of a bitch! I did that on my '62. I borrowed a jig from a guy that had one......made it tons easier!
August 30th, 2012, 02:47 AM
#96
Re: DD's 63
Lookin good Double D
I like those Chevy headlights, I'd like to get some old light buckets like those
I'm also getting ready to put some IRS brackets on my 66 swing axle floor pan, but 1st I'm gonna make me those brackets using an old rusted IRS rear torsion housing so I get them in the correct position, only reason I'm doing that is I have other plans for the swing axle
So, when are ya gonna be ready to start driving it ? or maybe I missed it when reading
August 30th, 2012, 06:12 AM
#97
Re: DD's 63
It shouldn't be that big of a deal making a pair of jigs. I'll have the IRS pan to build them from. Now doing the install with the body on might be a bitch but isn't that just part of the challenge and reward?
Ron, Thanks!
I would really like to have it on the road and reliable by the end of the year but only time will tell. I will have it drivable before I do the conversion .
August 30th, 2012, 09:37 PM
#98
Re: DD's 63
Photos of the toppless SB.... after I rape it of it's parts and my 63 is on the road, I see this one as an RPU. my 14 y/o daughter agrees and would love to own it.
September 3rd, 2012, 09:52 PM
#99
Re: DD's 63
I gambled on my parts car hoping the engine was in good condition. my experience and gut feeling proved to be right, the engine is in great condition. 5 hours of cleaning and prep, a little tuning and she runs like a champ.
Video
October 10th, 2012, 09:12 PM
#100
Re: DD's 63
| Thread Tools |
| Display Modes |
