Members: 17,694
Threads: 32,301
Total Online: 429
Newest Member: Dundy1968
Old July 16th, 2011, 12:31 PM   #1
63-chop-Va.757
Default ?? DROP SPINDLE HELP .. I would have thought it would have been easy !!
well VRs im tryn to install my 2.5 front spindle on my 1963 with disc brakes and I have come to a stopping point . Im not sure how to or if im doing this right......
I cant get this part off the put on the new spindle
63-chop-Va.757 is offline   Reply With Quote
Old July 16th, 2011, 01:35 PM   #2
Double D
Double D's Avatar
Default Re: ?? DROP SPINDLE HELP .. I would have thought it would have been easy !!
press out the link pin bushings which will expose the king pin, press that out swap spindles then reverse the process to put it all together!
Or, you might have to take them to a vw shop to have them done!
My .02
Old July 16th, 2011, 01:58 PM   #3
63-chop-Va.757
thkx .. i was not sure how to get to the kingpin, but now I see !!!
i think the KING PIN needs to be pressed out at a SHOP i cant get it to move
Old July 16th, 2011, 06:15 PM   #4
ratlook63
ratlook63's Avatar
Much easier at a shop. You can press them out if you have a press, but reaming the new bushings out is a bitch unless you have the right tools.
Wanted:
Split tail lights. Repop ok!
My Band
Old July 16th, 2011, 06:16 PM   #5
ratlook63
ratlook63's Avatar
And if those are CIP1 spindles you may need to ream them as well. Mine were cut well under a stock KP
Wanted:
My Band
Old July 16th, 2011, 06:54 PM   #6
63-chop-Va.757
i got them out and installed in the new drop spindles..
so im at the piont where im putting it back together and im woundering do you adjust the lower front beam or the upper beam to make it match up to the spindle ?
Old July 17th, 2011, 06:05 AM   #7
Dbug41
Dbug41's Avatar
adj.the one that will bring it parallel with the other in the horizontal position.
BEAM EXTENDERS 101 THE BASICS
Give me a like on facebook
life is short make fun of it!
Old July 19th, 2011, 07:57 AM   #8
63-chop-Va.757
well i finished it up the other night.. BUT
my bug already had beam adjusters - Plus - know I have the 2.5 drop spindles. and it just didnt seem like i lowered it any more than it already was..
HOW DO I GET LOWER ??? DO i need a custom beam, or is there any thing else i can do with what is stock and i have already done
Old July 19th, 2011, 08:36 AM   #9
Dbug41
Dbug41's Avatar
Post a pic of the grub screw location
Old July 19th, 2011, 09:07 AM   #10
63-chop-Va.757
im low now i guess, the bottom of my front lower beam in a 7'' off the ground
Old July 19th, 2011, 09:38 AM   #11
http://www.volksrods.com/forum/showthread.php?t=28233
Directions in there to raise and lower..
With an adjustable and drop spindles, you can get very low.
Old July 19th, 2011, 02:28 PM   #12
From the photo it looks like you top adjuster is set for being lowered and your bottom adjuster has the beam raised. They are fighting eat other.
Back the lower adjustment screw out so the that the aluminum block is touching the nut that is welded to the adjuster.
Old July 19th, 2011, 03:00 PM   #13
63-chop-Va.757
i just tryed that even with the car jacked up. Also with it on the ground. but did not move down or go any lower
i guess the aftermarket beam will get it slammed witch gives the 5.5 drop
Old July 19th, 2011, 05:48 PM   #14
Have you tried adjusting them all the way down and then bouncing the front end to get the pieces to "settle" in to place?
Old July 19th, 2011, 06:36 PM   #15
63-chop-Va.757
the block is down lower inside the bracket as it should be.. i just dont think the front end got any lower.. it might be at the lowest piont i can get with the adjusters and drop spindle
Old July 19th, 2011, 08:42 PM   #16
Rawbdad
Rawbdad's Avatar
are you running an extension? When I went adjusters and drop spindles, My front beam was 6" off the ground at its lowest, now I am running 19" rims and tires off a toureg so they are very meaty and probably add at least 4" but my frame head is definitely lower, which is the built in angle of dougs extension.
I guess what I am pointing out is where are you measuring your height?
what size tires you running?
is that a home built extension?
what are some of the other factors?
Rawbdad is offline   Reply With Quote
Old July 20th, 2011, 08:27 AM   #17
63-chop-Va.757
they are not home made. it is some old school adjusters that im sure where put on the cars year and years ago ! even the paint job and body work is olskool >> they filled in all the body molding trim holes.
my tires are pretty tall it is on the stock rims
tires front 165/15/86T
i think a smaller side wall tire will def help the drop
thkx VRs !!
Old July 20th, 2011, 05:26 PM   #18
ratlook63
ratlook63's Avatar
Take a look in the techbin for a tire size chart by scott76 alot of good info!
heres the link:
http://www.volksrods.com/forum/showthread.php?t=31099
Wanted:
My Band
