| Stuff to check out... |
| Forum Stats |
Members: 14,579
Threads: 30,745
Total Online: 62
Newest Member: benkajaks
December 6th, 2011, 08:00 PM
#176
Re: Project Doppelgänger- Rod/Aircooled meets Watercooled
December 6th, 2011, 08:14 PM
#177
Like the rest of your project, it looks really clean and well thought out.   What brand Heim joints are you using?
December 6th, 2011, 08:20 PM
#178
Thank you!
They are QA1 units from Speedway Motors.
December 7th, 2011, 02:41 PM
#179
Here is a couple shots at ride height. Almost perfect-
Fully lift should be about 2" above this.
December 7th, 2011, 03:42 PM
#180
Man,,, I hope this works... Now that I see more clealy of what you are trying to do,, Im seeing a potental problem with heim joint (multi angle swivel joint) being so far way from the CV joints... It may wobble around a bit with the extra lenght and leverage..
Of course you know the cure... OUCH
Again,,I hopeing Im wrong and all that nice work really works out like a champ!!
December 7th, 2011, 04:15 PM
#181
Not sure I understand. All of the joints will be locked in place with a jamb nut when its all sorted.... no wobble there. As for the "dropped balljoint" it is all locked in place with the 3/4" nut on the bottom. The 1" piece of DOM acts as a spacer as well as adding extra strength. The pinch bolt on the spindle keeps the main bolt tight.
Does this answer your concerns? Please let me know. I am always down to hear others perspectives. Some times it just best to have another set off eyes on the project.
December 7th, 2011, 05:31 PM
#182
Not meaning to offend.. Your work is excellent... but Im seeing a problem with the geometry compated to the stock set up...
The stock set up has the ball joint and the A arm pivots as close to the centerline of the driveshaft as practcal... This keep everything on the same plane for smoother pivoting.. By haveing the A arm pivot so low the heim joint has a different arc.. But this isnt an off road machine that needs or will have a lot of travel..
Im thinking that by haveing the extension to the heim joint doesnt give a solid footing for the strut bottom and it may move around... There is one way to find out.. and youre almost there..
Thats the thing when breaking new ground...
Maybe some sort of dog leg welded to the A arm to put the heim joint back up to the stock location under the CV joint..
December 7th, 2011, 06:32 PM
#183
No offense taken. Always love another view. Just having conversation.
With as low as this truck will be (even at ride height) moving the joint down actually restores much of the stock geometry... within reason. I have already tried the "Z'd" control arm trick. This works good for eliminating binding but the geometry is still all wacked out. Here is a diagram to help explain-
You are correct regarding the axles but there the only way around this is to move the motor up and well... that will likely not be happening. LOL
The fact that I am having to narrow the front end by 5" total kind throws a huge wrench in the machine. Basically I am just trying to restore some of the road manners back into the truck. I will also be dropping the tie rods similarly. This should help keep the steering decently sorted from full lift to laid out.
Your right though... I am moving into uncharted territory. We'll see how it all plays out this spring (fingers crossed).
December 7th, 2011, 07:48 PM
#184
I believe that this falls into the catagory of "If it were easy, everyone would do it."  I'm looking forward to see how she turns out.
December 8th, 2011, 10:50 AM
#185
It damn well better be!
December 8th, 2011, 09:35 PM
#186
All money dependent.
Got the rear control arm mounts all worked up-
December 9th, 2011, 07:09 PM
#187
December 10th, 2011, 11:34 AM
#188
December 10th, 2011, 12:07 PM
#189
dude your a beast cant wait till i get my shifter for my rabbit
 WHY NOT?
 GET SOME
December 10th, 2011, 10:27 PM
#190
I just got a call late Friday that your powdercoat was done. ;)
December 11th, 2011, 07:58 AM
#191
Hell yea great news,I love MK1s as much as my A/C VW , but mine is no where near as bad ass.
 WHY NOT?
 GET SOME
December 13th, 2011, 09:42 PM
#192
Almost completely done with the rear air ride kit. Need some more DOM for the upper links (yes... I cut them too short). Last pieces to sort out are the shocks (hopefully tomorrow).
Right side tank clearance-
Filler and breather hose clearance. The breather hose is actually quite a ways away. The picture creates the illusion that it is much closer-
Here is a shot with axle hanging way down to demonstrate the triangulation it has now-
December 15th, 2011, 01:41 PM
#193
OK... I think I got the shocks sorted. I wanted something that would fit the bill and was easily accessible-
Chevy S10 shocks. Perfect size and they used the same shock 82-04. Should be no problem finding them anywhere. They should be here tomorrow so I can get them mocked up and see where we sit.
More pics coming soon!
December 18th, 2011, 12:46 PM
#194
December 19th, 2011, 11:03 AM
#195
the rear looks good...and so does the jetta
 WHY NOT?
 GET SOME
December 28th, 2011, 09:15 PM
#196
Finished up Slam Pan and T2 shifter orders-
I was able to break loose a little time to finish welding up my control arms. Super pleased with out they turned out-
January 1st, 2012, 11:54 PM
#197
January 2nd, 2012, 07:01 AM
#198
Nice !
How do you know your limits unless you exceed them?  "Patina my ass....That's RUST !"
January 2nd, 2012, 07:07 AM
#199
X-2
Until next time...
67' Volksrod 2276cc (sold)
72' Baja Champion SE 1776cc
66' Volkstruck 1641cc
January 2nd, 2012, 07:35 AM
#200
Cool!
Those mounts thick enough?
Jim Buys
Vintage Speedwerks
Vintage VW's and CUSTOM Vinyl Graphics
Oklahoma VW Club
www.oklahomavwcruisers.tk
| Thread Tools |
| Display Modes |
