Members: 17,422
Threads: 32,268
Total Online: 517
Newest Member: J&P
Old June 7th, 2003, 03:44 AM   #1
PunchBuggy
Hi I am a long time reader but first time poster. You guys have some of the greatest ideas that are very inspiring. Allright enough with that crap. :D
The clutch on my 69 bug died today (but i got her home after a very strategic 5 mile drive in los angeles at rush hour [img]style_emoticons/<#EMO_DIR#>/eek1.gif[/img]) anyways i have to fix it but i saw a
1973-74 Porsche 914 trans for a hundred bucks and was wondering if i could drop that in my car with a 1600cc dual port stock engine and still have some pep.
Thanx for you time
PJ
P.S. Damn nick you do have some balls with Runtrod [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
I wish i could do that [img]style_emoticons/<#EMO_DIR#>/licklips.gif[/img]
Did my car make that noise?
PunchBuggy is offline   Reply With Quote
Old June 7th, 2003, 04:20 AM   #2
d1zoomers
welcome aboard. the porsche tranny is for a mid engine set up. you could do it but a lot of fabrication would be needed to put your engine in the luggage area and the trans where the engine use to be.
d1zoomers is offline   Reply With Quote
Old June 7th, 2003, 04:42 AM   #3
PunchBuggy
Duh that makes total sense. I like the five speed idea :D but not the mid engine cutting :mellow:. If i'm gonna start cutting it will be the roof first :)
Thank you very much though.
Old June 7th, 2003, 09:45 AM   #4
ShutupandDrive
ShutupandDrive's Avatar
you don't have to run it mid-engine. You can just flip the ring and pinion and it will operate the other way. People do it to VW trannys all the time. It's still won't be a straight drop in and willl require some fabrication, but not nearly as much as running it mid-engine.
-just jeff
yeah, I'm still lurking around...
57 ragtop and a 08 gti daily driver
ShutupandDrive is offline   Reply With Quote
Old June 7th, 2003, 10:24 AM   #5
crack monkey
crack monkey's Avatar
glad to see you posting!
the mod is covered on a bunch of germanlook sites. try www.germanlook.com and i dont know if it is still there but stf had a good article on it too. not a direct swap but a worthy one. gofor it and make it work [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Old June 7th, 2003, 10:27 AM   #6
I have a how to article too on my website articles section (link on signature)
Old June 7th, 2003, 12:47 PM   #7
Ianvwsb73
Guest
Posts: n/a
Ummmm, I don't think this tranny is the 901 which all the germanlook folks are running, I don't think the 914's had the 901, but I'm pretty sure the 911's did. The basics may still be the same, but I'm not sure. The 914 had a type4 in it. With some modification, you could put the 914 tranny in and also put in a beefy type4 for more power. peace, -Ian
Old June 7th, 2003, 12:58 PM   #8
Gravedigger
Gravedigger's Avatar
Thats a side shifter trans, it woun't work, ya need a 911 trans,#901.
Denny Anderson
Gravedigger is offline   Reply With Quote
Old June 7th, 2003, 01:30 PM   #9
d1zoomers
is it true that if you flip a trans, swap around the ring and pinion, that the gears wear out faster? i think i read this somewhere. either here or stf. i'm not sure.
Old June 7th, 2003, 04:38 PM   #10
Gravedigger
No, floping the ring gear has no affect on the wear, a swingaxle bus has the ring gr floped 'cause the reduction boxes reverse direction.
Running the R&P backwards will wear it out quickly(ie corvair power, the motor runs counterclockwise), how much or how soon? I don't know. I think you would get 60k-75k+ mi out of a R&P IMO.
Denny Anderson
Old June 8th, 2003, 08:13 PM   #11
Dr.Freakinstien
I'm putting a 901 from a 65 911 in my "B. o' Dr. Freakinstien" now.Some fabrication to make a mount,the torsion bar for the rear has to be "modified" ground down a bit,a different shifter bar and shifter from the 911 and porsche starter and I think that's all.It sure is a whole lot easier with the body hangin' in the garage though.Good luck.
"I recomend amputation!"
Dr.Freakinstien is offline   Reply With Quote
Old June 9th, 2003, 09:58 AM   #12
PapaG
PapaG's Avatar
Some of the 914 (early) used the nose cone shifters. The Porsche guys don't really like that tranny. When I bought my 2.0 L 914 engine the guy said he usually gets $100.00 for the front shift and $200-$300 for the side shift trannies. I think it is the side shits trannys shift better or something like that,
Dare to color outside the line. Think out of the box. Be the box. 69 Fastback, 69 Chopped top Squareback, 87 Syncro Vanagon, and more useless projects in the yard to make any redneck jealous.
PapaG is offline   Reply With Quote
Old June 9th, 2003, 10:07 AM   #13
Ianvwsb73
Guest
Posts: n/a
Originally posted by PapaG@Jun 9 2003, 09:58 AM
...the side shits trannys...
Talk about sloppy shifting. [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
Old June 9th, 2003, 10:17 AM   #14
PapaG
PapaG's Avatar
:P :P :P
Old June 9th, 2003, 01:57 PM   #15
lilbill
the tailshift trannys had some really rube goldberg linkage. after a little wear in the various sockets and couplings it was a bitch to find all the gears. and forget speed shifting. the trannys themselves were super tough but the linkage sucked bigtime
lilbill is offline   Reply With Quote
Old June 9th, 2003, 01:57 PM   #16
lunatic_magnet
lunatic_magnet's Avatar
been there done that.
go here and click on the 1971 superbeetle. there are pics and stuff about halfway down the page.
http://fly.to/wikked
