Members: 17,522
Threads: 32,241
Total Online: 507
Newest Member: Harold
Old November 16th, 2011, 08:32 PM   #1
type3guy
type3guy's Avatar
Talking the ls1 notch project
Hi to all this is my first post here and wanted to share in my new project with a perfectly good 64 notch. This project is being planned out as good as i can. I am hoping to go pick up the first part of the project which is the frame sections and suspension parts and start building. I have been working hard on everyone else's projects and motors along with builder bugs to sale to get the funds up for this project. I will have help building the frame because this car will also be going to the track and with the amount of power i want to go straight. This car will take me a little time but will be so worth it in the end. To the purest on other web sites out there it's my car and will have fun cutting it up to make it mine and that is why i like this site. Here are a couple more pics of the notch and some of the things i build. Can't wait to talk to you all and get more ideas and help any of you with anything i can. I posted info about myself in my build thread. Thank for reading.
type3guy is offline   Reply With Quote
Old November 16th, 2011, 10:56 PM   #2
Kraut Taco
Kraut Taco's Avatar
Default Re: the ls1 notch project
Nice, looking forward to seeing more of this project. Your right about making this your project and to have fun doing so.
Kraut Taco is offline   Reply With Quote
Old November 17th, 2011, 06:33 AM   #3
38Chevy454
38Chevy454's Avatar
Sounds like a nice project, but most of your pics are not of the notch. Let us see more of that.
Old November 19th, 2011, 03:00 PM   #4
Check out TJM's build on his V8 Square. It's got a really nice frame!
mkparker is online now   Reply With Quote
Old November 19th, 2011, 08:39 PM   #5
type3guy
type3guy's Avatar
I have seen the frame but i am building one from alstons chassis works that gives me a little more freedom to place the motor. Started taking out the front end sheet metal to get ready for the ls1 to fit. Big bummer part is the usps lost my $5100 check going to alstons and they say they have 90 day to resolve the issue which happens to be how long the bank check is good for. The bank has canceled the check but will not issue a new one till the usps takes responsibility for it and they wont. So onto cutting and making room. Back to the frame this one is being built with double adjustable coil over shocks in all four corners a-arm front suspension and 4 link adjustable rear suspension with ford 9 inch and a track loc diff.
Old November 20th, 2011, 08:51 AM   #6
Good grief..that blows! At least you have something to keep your mind off of the whole ordeal for now.
Old November 20th, 2011, 08:31 PM   #7
type3guy
type3guy's Avatar
well got a little work done today removed the forward firewall if you want to call it that. I think the people who put these cars together got paid by the spot weld lol. Next i have to start removing the rear panels that cover the wheel wells to widen them for the new wheel and tires and there are a ton of spot welds in a small space.
Old November 20th, 2011, 08:45 PM   #8
type3guy
type3guy's Avatar
and for those who have not seen the power plant for this car here it is.
Old May 21st, 2012, 09:44 PM   #9
type3guy
type3guy's Avatar
Hi to all again here is some updates. Well after a little more than 9 months of dealing with post office and the bank i finally got my money back. Then it took some of that time to get the parts from alstons chassiswork due to broken cnc machine. I got my parts and man it feel good to really get started. the back of the car out assembled frame front suspension and set motor and trans. Test fit the body and wow its crazy how fast the frame come together.
Old May 21st, 2012, 10:03 PM   #10
type3guy
type3guy's Avatar
some more pics and wheels i'm running
Old May 22nd, 2012, 06:18 AM   #11
1jarhead2
1jarhead2's Avatar
I had a fastback sitting in my driveway and measured out the front trunk space,thinking the same thing,what a great space for a LS engine. A LS Notch is even better,cant wait to see this one come together.
Old May 23rd, 2012, 11:40 AM   #12
72 Squareback
Old May 23rd, 2012, 04:16 PM   #13
jake1974
jake1974's Avatar
are you on ls1tech.com ? in the hybred section? if not its an awsome ls1 site, crap loads of ls1 info
jake1974 is offline   Reply With Quote
Old May 23rd, 2012, 06:59 PM   #14
type3guy
type3guy's Avatar
no, not on ls1 tech but will check it out, thanks and a few more pics. Dash gone and covers over heater duck to dash vents. Also the 9" getting narrowed and set up for 4 link. Here is a pic of the motor mount and some of the welding (frame is upside down in pic)
Old May 28th, 2012, 10:14 PM   #15
type3guy
type3guy's Avatar
Dash is now gone and the frame is fully welded. Rear end ready to be welded up. no pic but all the air tunneling is also been removed.
Old October 14th, 2012, 09:35 PM   #16
type3guy
type3guy's Avatar
I know it's been awhile but progress is being made. Been real busy at work and side work. Rear end is done with a tracloc diff 3.89 r&p with 31 spline curry axles and disc brakes. The roll cage is just about done and body welded to the frame. Still looking for a dash to use. Motor is all mounted after we moved it forward 4" and also had to move the main hoop back and is in the quarter window a little. Headers are being worked on and are looking good. Can't wait to get into a full roller. Also in this time away picked up the wife a project of her own a 61 2door falcon which will get some major updates of its own.
Old October 15th, 2012, 08:59 AM   #17
Progress looks great!
Old October 19th, 2012, 07:07 PM   #18
I agree...great so far...even slow progress is progress!
Old October 20th, 2012, 06:58 PM   #19
KdFmangler
KdFmangler's Avatar
man i am loving it. my dad has an old notchback behine the shop. i keep thinkin gof doing the same thing but with a 1st gen sbc. keep plugging away.
My PhotoBucket Pics
https://www.facebook.com/pages/Hotro...18525414956399
never arque with an idiot. they lower you to there standards and beat you with experence!
http://www.droppedaxleproductions.co.../DAPindex.html
KdFmangler is offline   Reply With Quote
Old October 26th, 2012, 10:52 PM   #20
type3guy
type3guy's Avatar
here are some pics of the finished headers mounted. These things fit but it's tight. In order to put in the o2 sensors i will have to go through the frame and weld in some tubes to get to the bungs. Now working on building the wheel tubs.
Old October 28th, 2012, 12:53 AM   #21
notched
notched's Avatar
Hi! I'm a first time caller. Just wanted to say I love this topic! Lookin' forward to more updates!
Phillip Bradfield
Old October 28th, 2012, 11:45 AM   #22
strokerbug
bitchin....
if i knew what i was doing, id share it with myself...
strokerbug is offline   Reply With Quote
Old November 1st, 2012, 07:33 PM   #23
type3guy
type3guy's Avatar
a little update with the start of the wheel tubs. Chris the guy that is helping with the sheet metal work does real nice work. The side and rounded top were two pieces before he rounded the edges and welded, then metal finished.
Old November 3rd, 2012, 06:19 PM   #24
StickerDick
StickerDick's Avatar
very cool!
Old November 13th, 2012, 09:01 PM   #25
type3guy
type3guy's Avatar
a little more cutting getting ready for new wheel tubs. Also picked up a dash for the car out of a 54 chevy bel air. the contour is real close the car and will give me the extra space under the dash for the ac.
