Members: 17,522
Threads: 32,241
Total Online: 491
Newest Member: Harold
Old June 9th, 2003, 06:53 PM   #1
fweem1970
how many inches can i take out of the beam before i need to cut in to the body? [img]style_emoticons/<#EMO_DIR#>/stoned.gif[/img]
fweem1970 is offline   Reply With Quote
Old June 9th, 2003, 07:16 PM   #2
p-nor
p-nor's Avatar
ball joint or king/link pin? you can take more out of a ball joint, i think something like 3 inches, i think a bit less out of a k/l. i'm just cutting 6 inches out of mine and maybe ditching the shock towers so cutting the body wont be a concern.
paul
oh... going off your name i'm guessing you have a 1970, duh. ball joint it is!
Old June 9th, 2003, 08:42 PM   #3
Gen
You can take 6 inches out of a beam on a balljoint bug... I think only like 2 on a linkpin (these are total, not per side)... but if you take enough out of linkpin, you can put the shock mounts inside the fender (raise the gas tank a bit)... I heard about this in hot vw's a few months ago... ummm... Tim Hess I think... red 60ish oval... don't remember very well and lost the issue.
Rob
I need to go back to bed!
Gen is offline   Reply With Quote
Old June 9th, 2003, 10:02 PM   #4
Growler
Or this is an option too. The beam is 5" overall, gas tank retains o.g. position and beam still has shocks.
I wish I was driving a cartoon car around a boob.
Growler is offline   Reply With Quote
Old June 10th, 2003, 06:44 PM   #5
Gen
growler... never seen that before... but I LIKE IT!!! *begins to rethink suspension setup*
Rob
Old June 10th, 2003, 07:16 PM   #6
is that sturdy enough? or is there additional reinforcment added as well?
Old June 10th, 2003, 08:57 PM   #7
Growler
The plate is welded to the body, what you don't see is where the bolt passes through the plate it is in a short piece of cro-mo tubing that is heliarc welded to the plate on both sides.
Yeah, it's sturdy enough. :P
All I'm saying is there is other options out there. I don't necessarily reccomend that anyone do this particular kind of mod unless they are fully qualified. My Dad has built several race cars completely from scratch and is capable, not everyone is...
Example:
Hope that helps.
Old June 11th, 2003, 06:56 AM   #8
PapaG
PapaG's Avatar
Is that a Pikes Peak car? Wow.
Dare to color outside the line. Think out of the box. Be the box. 69 Fastback, 69 Chopped top Squareback, 87 Syncro Vanagon, and more useless projects in the yard to make any redneck jealous.
PapaG is offline   Reply With Quote
Old June 11th, 2003, 11:42 AM   #9
Growler
Yeah it is. Used to run a F.I. 2400cc until the rule changes forced us to step it up to a V8.
700 HP, Porsche 930 box, twisty dirt roads...the thing is a beast. No I don't get to drive it. :D
Old June 11th, 2003, 04:13 PM   #10
Just for reference purposes.
If you have a early body on a late pan. You can not narrow the beam as much as you could with a late body. You will have to clearence the the body a bit. I did mine 4" so I needed to clearence the body some I cut a 2 1/2"wider than the existing space wedge out of a 2X4 and hammered it down between the the stock length beam. I know not the greatest metal working technique .... But worked quickly and you can see it.
