Members: 14,584
Threads: 30,747
Total Online: 62
Newest Member: chandlerg94
Old April 26th, 2012, 01:22 PM   #1
Boes
Boes's Avatar
Default home made swamp cooler
Some time ago I was watching TV and on discovery there was a show about restore and sell of classic cars.
those guys were restore a 50's car and put a swamp cooler on the window of the car.
I wanted one too!
but in the search on the net I noticed that these swamp coolers are very expensive here.
too expensive...
so I try to build my own,
I'm using a couple of old fire extinguishers a big and a smaller one for the basic shape.
after the top is cut off I flip the top and put in the largest fire extinguisher.
this providing a nice hole where the wind pass through it.
I took some sheet metal for the water tank.
after bending it over a 2,5 inch pipe it looks allright.
time to cut
after some spot welding I made a templet of te front and rear of de tank.
and weld it shut.
in the first picture you can see how it will look like when finist.
although I think the hole needs to be bigger
now that was all i know but I do not know what a swamp cooler should look like on the inside.
I do know there should be a type of fabric material in it on a roll.
but does any one know wat I have to us
If you choose not to decide, you still have made a choice!
see my build klik here
Old April 26th, 2012, 01:46 PM   #2
Choppercabra
Choppercabra's Avatar
Default Re: home made swamp cooler
Looks killer so far.
They carve their marks in your flesh
to attest to the fact
that we can't forgive and we won't forget.
Choppercabra is offline   Reply With Quote
Old April 26th, 2012, 02:23 PM   #3
jake1974
jake1974's Avatar
shit ! i was hopeing you had it done . so i could copy it. they are 300 to 400 dollars rite now on ebay.
jake1974 is offline   Reply With Quote
Old April 26th, 2012, 02:51 PM   #4
http://www.thesamba.com/vw/forum/vie...ight=thermador
Old April 26th, 2012, 03:13 PM   #5
It appears to have an inner section that the water wicks up into and once the incoming air passes by it through the venturi differential it cools the air which in tern creates a cool air that enters the cab area. It also appears to have a flap that is able to be moved to shut off the air when wanted. I wonder if some of them had some kind of fan that helped in creating more air flow into the cab.
Old April 26th, 2012, 06:11 PM   #6
PureC4
PureC4's Avatar
that is great, I had an idea of using a marine grade Bazooka speaker tube, but they are impossible to find blown. May have to try and copy your idea down the road. Any how looks great and easy on the budget.
Old April 26th, 2012, 07:08 PM   #7
Pop
Funny -- I have been around VW's since 1956 and never seen a swamp cooler except at a car show. Wrong part of the U.S. I guess. Pop
Pop
Old April 26th, 2012, 07:27 PM   #8
Hapster
Hapster's Avatar
They only work in dryer climates. They cool by adding humidity to the air.
They don't work where I live now!
quote from cdscowboy
I totally feel at home here.
project pics
Old April 26th, 2012, 07:48 PM   #9
sandfreaks
sandfreaks's Avatar
Very cool!
Great use of existing materials.
Old April 27th, 2012, 12:34 PM   #10
I rebuilt one quite a few years back. The material inside was much like the coarse hair orange-ish material found in the stock VW seat bottoms.
I'll see if I can find the pics I took of the guts.
Cool project, man!
Old April 27th, 2012, 12:47 PM   #11
Pick your poison... http://www.comfortgurus.com/index.php/cPath/25_116
Old April 27th, 2012, 10:44 PM   #12
btrghia
The pads are. Well cooler pads. They call them Aspen here in az. They work great here. The pads in the car window coolers mount to a wire cage that can be rotated through the water. Kind a ratchiting deal.
Good luck finding pads where you are. If need be I can ship you some but I imagine the shipping will be far more than the pads.
64 karmann Ghia convertable
Tucson, Az
btrghia is offline   Reply With Quote
Old April 28th, 2012, 02:18 AM   #13
Boes
Boes's Avatar
yes I guess so too..
think I have to google some more for something more out of europe..
the idea is to do it low budget
Old April 30th, 2012, 12:10 AM   #14
I assume Holland is humid and a swamp cooler would not work.
While I am assuming stuff about a place I have never been to, I assume it does not get hot???
Old April 30th, 2012, 11:59 AM   #15
it gets hot there! gets up into like the 40's (F) I think...
2009 Dodge Challenger R/T "Folsom Blue"
