Members: 17,542
Threads: 32,283
Total Online: 476
Newest Member: clara5174
Old May 8th, 2012, 05:26 PM   #1
jkien65
jkien65's Avatar
Default Fan Rubbing
Re:: In the fan shroud
Any one have the problem of the fan rubbing the back side of the shroud? I took all the shim out and it still rubs. Are fans all the same thickness? Are there different thicknesses? It was working just fine til I had a little issue with bolts coming loose and the the fan getting stuck and screwing shit up.
So I have a fan out of a different shroud and I put it in the one that is in the car and it rubs. Getting pissed. Anyone help me out here?
jkien65 is online now   Reply With Quote
Old May 8th, 2012, 05:33 PM   #2
Default Re: Fan Rubbing
A dog house fan is wider than an earlier model. Are all 3 pieces there on the backing plate? Should be the plate that sits on the alt/gen, then a round spacer and then the plate with the vent pointing down.
Old May 8th, 2012, 05:50 PM   #3
jkien65
jkien65's Avatar
All 3 pieces are there, I will have to double check that the vent is pointing down. The fan shrouds are the same type. I dont know if it rubbed in the other shroud tho.
Old May 9th, 2012, 04:45 AM   #4
blacktruck
blacktruck's Avatar
once I had to put a beer can shim between the stand and the gen to make a rub go away
nut up or shut up
Old May 9th, 2012, 05:54 AM   #5
Are you sure it's rubbing, or could it be the generator bearing?
I was thinking my fan was rubbing on something, but it doesn't bother me so it's just gonna hafta rub until I feel like taking it all apart again
It started rubbing when I had to replace my generator with an alternator because the voltage regulator went out, the alt has an internal regulator
I think it's the rear bearing in my alternator, it's been sitting since 97 when I blew the engine in my rail buggy
I think from all the dirt & water that got inside it rusted or just corroded it, so as long as it works I'm not gonna fuck with it until I have another reason to take it off
Old May 9th, 2012, 06:13 AM   #6
jkien65
jkien65's Avatar
Yeah its the fan rubbing on the shroud. There are 2 rows of tabs that hold the fins in place. The outside row is all shiny on the ends and there is a wear mark on the inside of the shroud. Im done screwing with it til saturday.
My buddy has a stock pile of fans so I am going over there on saturday to do some measuring to see if I can find a slightly thinner fan. I dunno what else to do.
Old May 9th, 2012, 06:53 AM   #7
Hammertime
Hammertime's Avatar
I had the same problem on a 1600 duel port,ended up loosening the alt strap and pulling the alt forward on the stand till the rub stopped,had to silicone a small nut between the stand and the lip on the alt to keep it from working it's way back but it's been running this way now for about 6 months without issue.
Hammertime is offline   Reply With Quote
Old May 9th, 2012, 07:15 AM   #8
jkien65
jkien65's Avatar
Hmmm, I will have to see what I can do. I gotta get this back on the road soon. Daily driving my suburban is killing me in gas.
Old May 9th, 2012, 02:33 PM   #9
sandfreaks
sandfreaks's Avatar
I had the same problem when I put the 1641 in the 67 in.
I finally used a Cardboard peice - folded it in half
and put it between the Alt and stand. I also noticed that the shroud
was able to move ever so slightly so tightened the side screws
with a pair of vice grips. You can also try moving that strap
a little forward or back. For some reason it makes a difference.
mice still rubbed ever so slightly but went away after I put some miles on it.
Old May 10th, 2012, 06:14 AM   #10
jkien65
jkien65's Avatar
Ok, sweet. I will check it out saturday. Seems weird that a shim between the alt and the stand would stop it from rubbing, weird. I will give it a whirl tho.
Old May 14th, 2012, 06:26 AM   #11
jkien65
jkien65's Avatar
Ok, worked o nthis problem this weekend. I had the backing plate in wrong, vent pointing up, but the fan was also to thick. I went to my buddies and we put the calipers top a couple of them. one was 1.26" and one was 1.23 inches. I opted for the 1.23" thick. I got it installed, no more rubbing. She is running like a top now.
Old May 15th, 2012, 04:16 AM   #12
blacktruck
blacktruck's Avatar
nut up or shut up
