Members: 14,771
Threads: 30,818
Total Online: 65
Newest Member: Kisling
- by jdinvt
- by bejay
Old May 14th, 2012, 11:55 AM   #1
bubba823
bubba823's Avatar
Default transaxle identification
i have looked multiple times, i have found a couple tables that show i.d # references but nothing with my numbers...
here is the numbers:
stamped on bevel on side of transaxle: 839673
above stamped numbers forged in case :
27
113 301 103
b
any help would be appreciated... thanks..
bubba823 is offline   Reply With Quote
Old May 14th, 2012, 12:51 PM   #2
Double D
Double D's Avatar
Default Re: transaxle identification
27
113 301 103
b
Look here
http://www.thesamba.com/vw/
Old May 14th, 2012, 05:07 PM   #3
bubba823
bubba823's Avatar
Looked again at transaxle, NO LETTERS STAMPED, and i didn't see last number...
Numbers stamped on side are:
8396734
I,ve looked on samba but only find same info...letters at begining..
Here are a couple photo,s also
Old May 15th, 2012, 05:56 AM   #4
There is a lot of info HERE
Yours is an old Type 1 swingaxle. What do you need specifically?
Old May 15th, 2012, 06:10 AM   #5
bubba823
bubba823's Avatar
thanks, that helps, any info on parts. will any clutch, flywheel, motor bolt up(VW) do i need to know the year when looking for parts?
also is this a link pin front and do i need to know year for parts?
Old May 15th, 2012, 06:20 AM   #6
bubba823
bubba823's Avatar
forgot photo
Old May 15th, 2012, 06:21 AM   #7
bubba823
bubba823's Avatar
oops..
Old May 16th, 2012, 06:31 AM   #8
Link Pin beams are from 1965 back. Pretty much any 1960's parts will work.
1966 and earlier swingaxles were 6 volt cars and used smaller flywheels. Here is a link
with more info: 6-12 volt conversion
Virtually any aircooled motor will bolt up to your transaxle. From what I have found on the 'net there is no "for sure" way to date most older VW transaxles reliably.
