Members: 14,607
Threads: 30,752
Total Online: 35
Newest Member: cyris3d
- by TJM
- by Limey
Old May 16th, 2012, 05:35 PM   #1
71vdub
Default Budget Rotary Beetle Build
Hey guys, got my hands on a decent beetle project for $100. HAS A TITLE . Its a 71 Super Sunroof. It needs a new key though, lost the old one. hasn't moved from where i dragged it out of since 1987, and the 4 wheels were all locked up (nothing a winch couldn't break free!). Anyway, I got it home, cleaned it up, washed it, and did some temporary "detailing" . Anyway, just pulled the motor out today and have a confirmed $450 coming my way, so I am in the market for an RX7 rotary adapter from Kennedy Engineering. I have a friend with a couple RX7's that I am getting. One is rusty and has no title but runs, and that motor is going in the beetle. So, ultimately, I'll have $550 invested in it total with the motor mounted. Then I figure another $300 for radiator tubing and lines and oil lines, plus misc. stuff that I'll need/want. So, for under a grand I could have a running, driving, titled, RX7 beetle. Enough of the jibber-jabber, heres some pics!
And mucho thanks to my slightly irregular friend Conner for his help in lifting/pulling the motor:
71vdub is offline   Reply With Quote
Old May 16th, 2012, 05:42 PM   #2
Default Re: Budget Rotary Beetle Build
if you run a jeep cherokee radiator in the back package tray area it just fits. The radiator hoses are in a relatively good location as well. The rotary is a finiky bitch in a bug. I solved all the issues with mine but blew the motor before i had to much road time. I did do alot of donuts in the yard before it went capute. Run a heat shield between the car and header or it will vapor lock
Old May 16th, 2012, 05:48 PM   #3
71vdub
Thanks for the tips. If I need advice Its nice to know theres someone here who went through the same thing. What year Cherokee radiator works? Do you still have your flywheel and adapter from yours? If so, are you looking to sell them?
Old May 16th, 2012, 05:57 PM   #4
Put some money into brakes,
pay attention to the hoses and hard lines.
Recently updated:
FlyingEyeballs.net
Old May 16th, 2012, 06:02 PM   #5
71vdub
Will do. I need the brakes done anyways, they werent working when parked 20 years ago, had a leak then...
Old May 16th, 2012, 06:06 PM   #6
Might as well replace everything.
And take a look inside the fuel tank.
The tank and line might be corroded as well.
Recently updated:
FlyingEyeballs.net
Old May 16th, 2012, 06:10 PM   #7
71vdub
The rubber lines are crap, they crumble in my hands. its getting new fuel lines at the least. the tank is coming out tomorrow and its getting a good look over
Old May 16th, 2012, 06:32 PM   #8
1jarhead2
1jarhead2's Avatar
I have a 12a rotary in mine and love it. It is the fastest vw beetle I ever owned and my last beetle had a 1835 with dual carbs.
Old May 16th, 2012, 06:38 PM   #9
71vdub
Nice! Mind if i pick your brain for a minute? How hard was the swap, generally speaking? How did you get the engine in, cut the apron or go in from under? What did you have to do for the exhaust? Where do you have your radiator mounted? and oil cooler?
Old May 17th, 2012, 03:32 AM   #10
OK let's inventory what you have to work with
1) SBW/title-no motor
2) two RX-7s - running & no title
3) kids
4) a place to build it
IF YOU ALSO HAVE
5) sawz-all
6) flux core MIG
let me suggest you put the SB body on the "best" RX-7
Let's walk through this.....
The SB & RX are both rear wheel drive and strut front suspension W/ R&P steering
Both are uni-body construction
IMHO
unbolt the SB body,
get a bunch of sawz-all blades and
Start cutting pieceses off of the RX-7 untill the SB body settles down on top of it.
the rest is easy
Old May 17th, 2012, 03:56 AM   #11
[ATTACH]Attachment 32939[/ATTACH]
Old May 17th, 2012, 05:20 AM   #12
38Chevy454
38Chevy454's Avatar
I did not think NC cars got so rusty, is that a northern car?
Also on your money estimates, double what you think and it will be closer to reality. Still $2000 would be cheap fun.
High Quality USA-made bear claw latches CHEAP! Now including install kits also!
http://www.jalopyjournal.com/forum/s...d.php?t=620485
Old May 17th, 2012, 05:37 AM   #13
1jarhead2
1jarhead2's Avatar
Mine is a litle different as the engine is up front and the radiator is in the back.
Old May 17th, 2012, 07:31 AM   #14
71vdub
3) kids
IF YOU ALSO HAVE
5) sawz-all
6) flux core MIG
IMHO
unbolt the SB body,
the rest is easy
Really think thats easier/cheaper? I mean, they sell a kit to bolt the motor straight up. But I see your point. Is there a thread on how this is done? and Also, the kids are me and my friend Conner. I have the glasses and hat, I'm 17. My friend Conner is the one wearing the hood as a hat. I'll be doing the work, Conner will be helping. I have 10 years of mechanical experience already
Old May 17th, 2012, 08:58 AM   #15
To know if a bug body will fit the RX, measure the wheel base center to center and width.
I would think it easier to do engine swap and mods.
Good luck with it. Nice to see someone so young doing something like this.
1,2, torch
Help support the best site on the web.
Rods-n-Kustoms sister site for non vw big iron
Popular OT threads
Old May 17th, 2012, 09:45 AM   #16
Wheelbase is close, RX7 is 900 mm wider,
on the tread width.
Plus, the rocker boxes (structural) are significantly
wider that the Type 1.
My guess, is it has never been done.
Recently updated:
FlyingEyeballs.net
Old May 17th, 2012, 10:20 AM   #17
Volks-Swap rotary Conversion
Rotary Beetle
Old May 17th, 2012, 11:16 AM   #18
71vdub
Honestly I'm just gonna pull the motor and buy the kit, then mount it. Hardest part will be running exhaust properly. I'm thinking of routing it under the car and forward, and out right under the doors like a muscle car, or right out behind the front wheels. And thanks, Mechanics is my hobby and passion.
Old May 17th, 2012, 11:26 AM   #19
GOOD! cuz you will find out, vws need a mechanic all the time , and not just for the motor either
1,2, torch
Popular OT threads
Old May 17th, 2012, 11:32 AM   #20
71vdub
Tell me about it . I have a lot of work to do on this beetle. Needs the battery bay replaced (battery falling through the floor) but the rest of the pans are solid. Also needs breaks done, gas tank cleaned and lines replaced, the throttle is stuck solid, and there is no key, so a locked steering column. But, I have the lock code so I'll be getting a key. Do you happen to know a good place that can make me a key from the code?
Old May 17th, 2012, 11:41 AM   #21
Check with a GOOD locksmith. Not just a place that makes/copies keys. I've had to get special keys for my bay.
Had a key ordered in and made for my bug, it's now inside the door til I get around to replacing it
But they should be able to order in the correct key and be able to make one. But they may ask you to take the tumbler out so they can do it.
1,2, torch
Popular OT threads
Old May 17th, 2012, 11:43 AM   #22
jkien65
jkien65's Avatar
No shit! I cant drive mine 2 days in a row without something going wrong.
Old May 17th, 2012, 11:46 AM   #23
Maybe should read the thread 'embarrassing things that happened to you, while driving'
1,2, torch
Popular OT threads
Old May 17th, 2012, 01:27 PM   #24
Scott76
Scott76's Avatar
Could be worse. Your engine could fallout while youare driving.... I'm sure that never happened to ANYONE in here before....
Bugger Off
Fleetwing Camper
Going to the Basement
Old May 17th, 2012, 01:44 PM   #25
jkien65
jkien65's Avatar
HEHEEHE very true. Yeah I cant think of any one that has happened to....? hehe.
