Members: 14,784
Threads: 30,827
Total Online: 40
Newest Member: squarebackjonesy
- by mundo
- by jkien65
Old May 24th, 2012, 09:43 AM   #1
dave7786
Default volksrod darting all over the road?
hi i recently picked up a volksrod project. everything is pretty much set up on the car, but on a test ride, the car darts to the left and right. i had the car aligned and it helped a little bit, but the car is still incredibly hard to control and drive. it will not drive straight normally it seems like i have to constantly fight the wheel to keep it straight. is this normal or is there something wrong? i thought a suspension piece might be loose but i havent been able to find anything. has this happened to anybody else and has anyone found a solution? thanks - dave
dave7786 is offline   Reply With Quote
Old May 24th, 2012, 09:45 AM   #2
Default Re: volksrod darting all over the road?
post pics of the front end and let us see. Sounds as if the front is lowered to much causing bump steer due to improper tie rod geomatry.
Old May 24th, 2012, 09:56 AM   #3
Rear suspension alignment? Post pics
Old May 24th, 2012, 10:07 AM   #4
Swing axle car ?
Lowered on both ends ?
Need more info.
UnkLian.net
FlyingEyeballs.net
Old May 24th, 2012, 10:08 AM   #5
Scott76
Scott76's Avatar
Need caster shims behind the bottom tube up front.
If the rear is a swing & has ALOT of camber the rear sometimes feels like it kicks out to the left or right on wet roads. OR the rear center axle nut isn't tight enough.
Bugger Off
Fleetwing Camper
Going to the Basement
Old May 24th, 2012, 10:09 AM   #6
Scott76
Scott76's Avatar
Wait.... This is a newb.
SEARCH!!!
OK I feel better.
Bugger Off
Fleetwing Camper
Old May 24th, 2012, 12:10 PM   #7
dave7786
Old May 24th, 2012, 12:13 PM   #8
dave7786
axle nuts are definitely tight i already checked those. it doesnt feel like the rear is sliding out it just darts back and forth.
Old May 24th, 2012, 12:47 PM   #9
GI Joe
GI Joe's Avatar
Sweet ride!! Good luck with your bump steer issue!!
Respect, Honor, Remember
www.NLEOMF.com
GI Joe is offline   Reply With Quote
Old May 24th, 2012, 12:55 PM   #10
That axle setup looks like one that was originally sold by RoadsterCliff who is a member on here. This is a link to his website http://www.vwstreetrod.com/vwstreetr...etrod.com.html
I would suggest going to the "contact us" page and talk to him about it.
Nice looking volksrod there Dave!
Old May 24th, 2012, 01:09 PM   #11
Alignment specs, front and rear ?
Steering box ?
Panhard bar ?
UnkLian.net
FlyingEyeballs.net
Old May 24th, 2012, 02:14 PM   #12
Hopefully, there is a panhard rod running off to the side we can't see. But from the pics I can't see what locates the front axle besides the shocks and the drag link.
Nice looking ride though.
Old May 24th, 2012, 02:28 PM   #13
Thunder938
axle angle tipped back..caster? should be 5 to 7 or more I think mine is like 9 degrees also if you used the hole in the steering box arm that is shorter it will speed up the steering. Make sure the panhard is close to level..
Old May 24th, 2012, 04:14 PM   #14
Any of you guys run a steering dampener? One couldn't hurt here once the setup is correct.
Old May 24th, 2012, 04:35 PM   #15
I saw that car and met the builder at a Wall Stadium Cruise night. He took it on track for parade laps and it looked fine then. I know he bought all the parts from the same guy in CA, I think. Good luck, neat car.
Old May 24th, 2012, 05:28 PM   #16
Just a small hijack...but the Moon Eyes on your V-Rod reminded me of this. Back in the sixties one of my buddies had a VW his folks had given him for High School, and they wouldn't let him do anything to her. He found a Moon Eyes decal that read "Soon Equiped, presently stock." And now back to our regular thread.
Old May 24th, 2012, 09:47 PM   #17
"Kid Casey"
"Kid Casey"'s Avatar
Aesome car man, paint it rad and ship it out to me.
Thanks
Casey
"2 Bits ta' Look N' a lil More ta' touch"
"Kid Casey" is offline   Reply With Quote
Old May 25th, 2012, 02:23 PM   #18
special-k
I don't see a panhard rod either. Our's wandered until we put one on. We have a shock on the drag link also.
special-k is offline   Reply With Quote
Old May 25th, 2012, 05:03 PM   #19
Steering box ?
Panhard bar ?
UnkLian.net
FlyingEyeballs.net
Old May 29th, 2012, 04:59 PM   #20
Must have magically fixed it's self.
UnkLian.net
FlyingEyeballs.net
Old May 29th, 2012, 06:26 PM   #21
Thunder and V8 are right on the money. If you could push the bolts out on the lower mount of the hairpins and pull back the tops, you might get a hair better caster.
Radial or bias-ply? Check to make sure you don't have rads in back and bias in front or vice versa. I've heard some run it like that with no probs while others have cars that aren't even drivable. It looks like you have radial Silverstones.
Old June 6th, 2012, 03:05 AM   #22
I once had a car with radial tires in back & bias up front, it was all over the road at speeds over 40 MPH, I put the radials up front & the bias in back & it drove a little better, was like driving a new car after putting radials on all 4 corners
My web site link
Old June 11th, 2012, 02:22 PM   #23
I just love it, when people post their problems,
frequently alignment related; someone trying to
help asks for specific details and they get nothing.
No reply, no details, nothing.
Why bother posting in the first place ?
Maybe this guy can help:
UnkLian.net
FlyingEyeballs.net
Old June 11th, 2012, 02:51 PM   #24
Originator was last seen here @9:49 am today~
Maybe it was something stupid and he's too embarrassed to tell it.
Guess others will have to learn the hard way then maybe they will tell us other inquiring minds....................
Old June 12th, 2012, 02:41 AM   #25
Dbug41
Dbug41's Avatar
From the lack of participation this thread is a dead end without resolution...
I feel so empty...
Oh wait I'm just hungry, carry on :)
The VolksRod Shop
2050 wall Ave
Ogden UT 84401
801 529-5153
BEAM EXTENDERS 101 THE BASICS
Give me a like on facebook
life is short make fun of it!
