Members: 14,783
Threads: 30,825
Total Online: 56
Newest Member: William Olsen
- by jkien65
- by jdinvt
Old August 7th, 2012, 07:23 AM   #1
Caliber32
Caliber32's Avatar
Default I need some disc brake clarification
Are the stock Ghia spindles what everyone uses to put on disc brakes?
Caliber32 is offline   Reply With Quote
Old August 7th, 2012, 07:43 AM   #2
Default Re: I need some disc brake clarification
Yes, that's what most of them are or are based on.
Old August 7th, 2012, 07:47 AM   #3
Caliber32
Caliber32's Avatar
Being that I'm a mechanic I figured I could piece together a kit with off the shelf parts from my local parts house.
Old August 7th, 2012, 08:37 AM   #4
Yep. That's how it was done before conversion kits. or you can but the kit with the bolt on brackets and no spindle swap is required unless you also want lowered spindles.
Old August 9th, 2012, 03:26 AM   #5
I have brackets that bolt onto the spindles where the drum brake backing plates go, then the calipers bolt to that bracket, but if you already have Ghia spindles with the caliper mounts then your set
The brackets have about a 1/4 to 1/2 inch off set so it all fits the rotors, making the brackets isn't that tough as long as you have the equipment to do it, much cheaper than a set of Ghia spindles, but that's only because I have more time than money
My web site link
Old August 9th, 2012, 05:06 AM   #6
Caliber32
Caliber32's Avatar
I got lucky yesterday and found a set of stock spindles for $35 shipped!
Old August 10th, 2012, 08:31 AM   #7
dublow65
yeah i know your a bad ass and you can do it with baling wire and duct tape/electricial tape works too and its black but anyway brakes are way overated
dublow65 is offline   Reply With Quote
Old August 10th, 2012, 05:45 PM   #8
Caliber32
Caliber32's Avatar
So glad you could join us Tony!
Old August 13th, 2012, 03:50 AM   #9
I try to limit my brake usage as much as possible, that way when the need to stop in a hurry comes around, I can count on them to work
My web site link
