Members: 17,604
Threads: 32,290
Total Online: 463
Newest Member: smoknjoe
- by Vrshack
- by bugwhat
Old August 9th, 2014, 12:49 PM   #51
Default Re: Effigy's history
alright, finally got out to the car today.. I looked at loctite tubes while at the store, and green is actually the recommended color for bolts that small, and I already had a brand new tube of it in my drawer, so I bought three new bolts, some external tooth lock washers and oil and a filter..
Went home and reinstalled the alternator backing plate, tried to drain the oil and discovered the oil pan I bought a few weeks ago is like an inch taller than the ground clearance under my exhaust..
Drove the car up onto ramps in the front to make sure the front stayed higher than the rear, then rolled my motorcycle lift under the rear to jack it up some.. discovered then that the jack rails BARELY cleared the exhaust.. threw a small road sign between the rails and some pieces of wood on top of the road sign so I would be lifting the oil plate and not the exhaust..
Lifted the rear end up enough to throw some jack stands under the stock jacking points, gave me about 2-3" clearance between the oil pan and the drain plug
drained out the oil, changed the filter, refilled with non detergent flat 30 and a bottle of Lucas zinc break in oil (lifters/cam only have about 1200 miles on em.. I'm sure it's fine, but I've never heard of extra zinc hurting..) and took it for a spin.
Old September 17th, 2014, 08:44 PM   #52
I haven't fired up the VR in a couple of weeks.. Right now I know my fuel pressure is a little too high (in-line gauge says about 4psi, should be 3.5..), and my carbs are running too rich, which is what I'm guessing is causing my mileage to be about 12-15mpg..
I've also got a problem now where it runs strong in all ranges in every gear, EXCEPT 2nd gear. In second, once I get to about 4200-4500RPMS it stutters like I'm only running on a couple of cylinders instead of all four.. My only speculation about this is maybe the rev limiter pill fell out of my 6AL box and it defaults to 4500? but it doesn't stutter in other gears so I don't know.. I keep forgetting to check to see if the pill is still there or not..
Anyway, I threw a bunch of money at AC.net, so I'm waiting on an order with two IDF rebuild kits, 50 exhaust gaskets, 50 intake gaskets, and something else that I forget right now..
I haven't found a vw shop really close to my house yet, so I figured I'd just stock up on shit that I will use eventually :P
Old September 18th, 2014, 07:47 AM   #53
If you don't get the fuel pressure down, you will still run rich with the new jets. The fuel will push past things. Are you running a mechanical pump? If so, add a second gasket as a spacer and see if the pressure drops. I have found that anything over 3psi for pressure in IDFs is too much.
Good luck.
72 Squareback
Old September 18th, 2014, 12:57 PM   #54
Good luck.
Running a Holley Red electric pump through a petrol king regulator.. not planning on changing jets as I'm still at roughly sea level.. I think the fuel pressure is just pushing too much gas in combined with improper screw adjustments..
Old September 18th, 2014, 01:47 PM   #55
If you run a return line off the pressure reg, you will also drop some pressure. Remember, right now, the restriction is just above dead heading a pump.
72 Squareback
Old September 27th, 2014, 04:08 PM   #56
So, with the Challenger going away.. State Farm is giving me a check for $14k ($22k minus what I still owed because I was an idiot and didn't buy gap insurance..). We're going to use almost $10k to pay off the wife's Charger so we won't have car payments anymore, and save some of the rest, and I'm gonna use some for some VolksRod upgrades..
Been looking at the A-1 exhausts since even though I LOVE how my dual glasspacks sound, it's made with some shitty metal that is rusting with a quickness out here in Virginia..
I'm thinking of a stainless steel sidewinder system with either the straight cherry bomb style muffler, or the magna flow one.. anyone have any experience with either of those? or recommendations?
Old October 2nd, 2014, 07:46 AM   #57
I have had great luck with Magnaflow on my stuff. Good sound, flow and at idle they don't drive the neighbors crazy.
72 Squareback
Old October 2nd, 2014, 12:58 PM   #58
I'm leaning heavily towards this one:
http://vwparts.aircooled.net/A-1-Sid.../a-1-swblt.htm
Old October 2nd, 2014, 05:41 PM   #59
Oooooh.....chrome....shiny!
Old October 3rd, 2014, 02:02 AM   #60
shiny chrome isn't why i want it.. being able to get it in stainless steel and the reputation that A-1 has for high quality is why i want it :P
Old October 26th, 2014, 07:16 AM   #61
Ordered the A-1 Sidewinder with that short "muffler", it should arrive mid-december..
Also bought some red JayCee pushrod tubes, and the hex idle jet holders..
Now when the exhaust gets here, I'll pull the exhaust, then carbs, rebuild the carbs and check my valve clearances (lots of clickity clackety right now..) then throw it all back together and cry for a few hours trying to tune the carbs again :P
Old October 28th, 2014, 05:41 AM   #62
Hafta let me know how those push rod tubes work out, they's expensive, but then again I haven't bought much over the last 16 - 18 years
I'll post a pic & description of the push rod tubes I started to make back in the early 90's in my VolksRod thread
Old November 21st, 2014, 02:01 AM   #63
Guess it's finally time I change my oil choice.. In California, I've always used 30 weight, it was fine, but it was also almost always the same temperature there..
It's been almost a month since I last started the bug, last time it ran, it sounded like the valves needed adjusting.. went out last night to fire it up (it's been in the 30's and 40 here this week..), took some carb cleaner down the barrels to get it to fire, and when it did, something popped and i saw a lot of smoke, so i shut it down and looked, and it looked like someone parked the exxon valdez in my driveway. Shined a light under and the rubber o-ring on my new oil filter was squeezed out..
My guess is that the oil was too thick, pressure built up too high, the o-ring was cold and then suddenly being heated, and the weakest point failed (the o-ring). That sound right to anyone else?
Thinking of switching to a 10w-30, maybe even 5w-30
Old November 21st, 2014, 02:02 AM   #64
I'll post here after i put em in, probably do it before adjusting the valves since it would have to be redone anyway..
Old November 22nd, 2014, 04:31 PM   #65
I've been running 30 weight oil year round in my VW's since around 1990, I've never had a problem, it was 12 degrees a few mornings ago, I have more trouble with the gear lube being thick
I'd also check the oil filter seal surface real carefully, a few years ago I bought a Scat oil filter mount, it was an 1/8" off from where the seal touched, I used the oil filter mount from one of my S 10 Blazer's, it has a pressure relief valve in it
Friday I finished a push rod tube, tomorrow I'm gonna try to get the other 3 finished, think I'm gonna modify them to take a 2 more o-rings just in case
Old November 24th, 2014, 07:03 AM   #66
Once I switched from the Fram HP1 to Wix/Napa Gold with a plastic plunger, I never had another problem...
72 Squareback
Old November 24th, 2014, 08:09 AM   #67
1slo3 what is the model/part number of the Wix/Napa filter your using? Thanks
Old November 24th, 2014, 01:04 PM   #68
It was a Wix I just blew up.. so I bought a K&N HP3001 and some Royal Purple 5W-30 tonight.. we'll see how that fairs once I get the time to put it in..
Old November 24th, 2014, 07:58 PM   #69
I use the NAPA Gold myself because they are close by.
72 Squareback
Old December 27th, 2014, 01:06 PM   #70
Going Stir crazy.. got a hand written note from AC.Net at the beginning of December, was a receipt for my order.. I'm guessing that means that A-1 started manufacturing my exhaust about 3 and a half weeks ago.. IIRC, it takes 8-9 weeks to build, so HOPEFULLY I get my exhaust (full system, j-pipes, header, merger, and "muffler") sometime in the next month or so..
I haven't touched anything on it because of the inevitable snowball.. I got a good sized list of things I want to do the next time I work on it, and I don't want to do twice as much work, so I'm basically twiddling my thumbs until the exhaust arrives..
Here's my plan:
1) remove old exhaust
2) drain what's left of the oil
3) remove rocker arms
4) remove pushrods/tubes one at a time to replace with JayCee Springloaded one
5) replace rocker arms and set valve lash
6) change oil filter
7) pull carbs and rebuild/deep clean
8) put carbs back
9) install new exhaust
10) profit! :D
Somewhere intermingled in there is going to be " cry" "scream" "throw shit" and "drink and call it a night and try again later"
By that time, all the xmas decorations should be back in their bins, and the bins stacked nicely on the side of the garage instead of in a pile where my damn car should be..
so once I have a place to park it indoors, I'm gonna tackle replacing the window scrapers for both front windows, and then my hope is to design door/quarter panels.
I made my own panels for my '73 super back in 2000, but I went completely stock except I deleted the map pockets and quarter panel ash trays.. this time I want to mess with some kind of design, maybe more than one color or something..
Old December 27th, 2014, 04:25 PM   #71
Thumbs down Re: Effigy's history
NEVER EVER use Fram filters.
They used to have a good name,
and made good products.
Somewhere along the line, they got
bought up by bean counters. Now they
make the cheapest crap on the market,
coasting on their reputation.
Old December 27th, 2014, 05:17 PM   #72
yeah I used Frams for years, but this one I just busted was a Wix.. replacing it with a K&N..
Old December 28th, 2014, 09:52 AM   #73
lakerat
Nice article about your car pariah. I would like to see some pics of your car finished with the front fenders back on. I was wondering how it all came back together with the front end extension and front fender clearance mods you had to do. I'm building a 1973 bug truck with a '40 ford nose but it will have fenders.
lakerat is offline   Reply With Quote
Old December 28th, 2014, 11:04 AM   #74
Uh... it's not getting front fenders..
but yeah, I haven't posted an new pics recently, i'll try and snap a couple next time I go out..
Old December 28th, 2014, 02:37 PM   #75
Here's my plan:
8) put carbs back
10) profit! :D
I didn't see add oil anywhere in that list after drain oil & change oil filter........ I think that's when the " cry" "scream" "throw shit" and "drink and call it a night and try again later" is going to happen big time!!!
VW INC.
'67 Baja
'63 T-Bird
Devils Plaything
