Members: 17,717
Threads: 32,305
Total Online: 475
Newest Member: greyeage9099
Old March 10th, 2014, 08:37 PM   #101
Default Re: Pre-A Outlaw replica.
You dont suggest that as an Outlaw I would do illegal things do you?
Old March 11th, 2014, 06:27 AM   #102
Well I would sure hope so!
Old March 13th, 2014, 12:09 PM   #103
New rear floor and firewall being built. Now also able to make a proper enginebay...
Old March 14th, 2014, 10:27 AM   #104
Today I picked up a pair of torsionplates I designed and had watercut for my diy adjustable irs plates...
Old March 16th, 2014, 07:40 AM   #105
Joe P
Its being tested for potential kit sales.
Yeah, thats it.
Joe P is offline   Reply With Quote
Old March 21st, 2014, 03:27 AM   #106
Now starting to work on enginebay and firewall. Decided to make a servicehatch from inside while I'm at it. Easiear access to startermotor and clutch adjustment, and also to enginebolts when I need to remove the engine.. :)
Old March 22nd, 2014, 04:54 AM   #107
The enginebay starts to look like it should be.... Still just spotwelded the sheets together.
Good thing as I never throw away anything so I found the frame around the engine that I cut out of the crewcab about 7 years ago.... used that and then bent some fresh sheetmetal that I then welded around it..
Old March 25th, 2014, 10:35 PM   #108
Enginebay sheetmetal fully welded and ready to be fitted to the frame..
Also decided to cut up and modify the new repro tachometer as it have incorrect chromering and too large diameter compared to original speedometer... I had an old universal VDO tacho for Diesels with correct diameter and chromering to adapt the 356 repro tach into...
Old March 26th, 2014, 06:25 AM   #109
This thing is rolling right along! Send it to me when you get tired of it!
Old March 28th, 2014, 12:21 AM   #110
You wish.....
Been slow the past months.. In weekdays I only manage to squeez in max. 1 hour of garagetime between work and picking up the junior from daycare.... :)
Yesterday I hammerformed the flange that will meet the firewall.
Hopefully I get time to weld the firewall and all the sheetmetal to the frame this weekend so I can start working on the frontend and upper mounts for the Mcpherson struts...
Old March 28th, 2014, 07:16 AM   #111
Originally Posted by Hebster-not playing nice-52 View Post
You wish.....
Well duh!
Old March 28th, 2014, 09:23 AM   #112
I swear you get more done in 1 hour than I get done in a month... I am loving the build
VW INC.
'67 Baja
'63 T-Bird
Devils Plaything
Old March 28th, 2014, 09:47 AM   #113
Originally Posted by hotrodheb View Post
Well duh!
I am Eeevil...
Old March 28th, 2014, 01:57 PM   #114
I am Eeevil...
And crazy!
And Dutch!
And....
And...
And...
Wait for it...
A Bastard!
Old March 30th, 2014, 08:47 AM   #115
Today I got the lower firewall and the surroundings finally welded.
The removable rear panel I will finish later when the body is back on.
So, next I started fitting in heating tubes...
Old March 30th, 2014, 09:49 AM   #116
As usual, a really nice job ...wait a minute...I see only four (4) cylinders ??
Old March 31st, 2014, 07:43 PM   #117
As you can see the rearpanel will be removable...
So you never know what will happen in the future. It is easier to determine if a longer engine fits under the body when the body is back on it...
Old April 6th, 2014, 03:12 AM   #118
Yesterday the butchering of the donor frontend continued. My plans in my head have been working innthe background and now I've got it figured out... I think...
I have to use the donorcars framehead as a jig for some rustrepair too...
Now cutting is done and it is ready to soon be fitted to the front...
Old April 23rd, 2014, 11:29 AM   #119
I hate springtime.. So much to do and so little time before driving season....
Just got into the rustrepair on the donorpart....
Old April 24th, 2014, 08:41 AM   #120
Today I made a huge repair patch ready for welding!
In the mail also some nice parts from CB and EmpiUS...
Old May 4th, 2014, 05:11 AM   #121
Finally took me the time to file down the bottompart of the custom steeringwheelhub so it fit nicely around the spokes on the old wheel.
Also found suitable clear Polyester resin to make the horn button so I finished the button. Fitted the logo into the splitbus button.
Then made a form from a spraypaint cap....
Taped the logo into the button as tight as possible...
Mixed 40g of resin that I poured into the form and kept my fingers crossed that the resin would cure...
Here finally with the form removed..
Today I sanded the front flat and sanded out the surface skin that was a bit tacky. Deeper in it was all cured..
After this I flipped it over and also mixed a small amount that I poured into the backside just for strength..
Old May 4th, 2014, 07:12 AM   #122
NICE
Old May 4th, 2014, 08:43 AM   #123
Slick work. I love your high tech paint cap approach!
Old May 4th, 2014, 12:57 PM   #124
Done!
Old May 4th, 2014, 04:51 PM   #125
Done!
Holy shit! What is this resin that you used! i'm highly curious! Hmmm making a shifterknob sounds appealing using that approach! wait don't tell me I'll actually use it! No please tell me this is cool! How'd you get it polished nicely?
