Members: 17,688
Threads: 32,298
Total Online: 92
Newest Member: gstong
- by Frank3
Old March 9th, 2014, 04:00 PM   #1
OHenry
OHenry's Avatar
Default Fresh Air project
Re:: body between the wheels
So I havent gotten very far yet but I figured I would start a build thread now. I picked up a 73 standard back in August/September last year and I tried to just drive it as is because my last couple projects just kinda burnt me out, and being a first time parent eats up ALOT of my free time and energy.
Basically driving it unmolested only lasted so long and I got bored so here we go!
Around november I got a 8" beam extender and brace from Dbug
Untitled by redrumvw3, on Flickr
So I got that installed and started to try and figure out a way to get the body between the rear wheels
So it hasnt been acomplised yet, but the plan of attack is going to be widening the rear torsion housing like the sand rails do and adding an extra 4-4.5 inches per side.
I'll also be doing away with the torsion bars and adding bags and the heim joint spring plate things so I can lay pan and have the body between the Wheels!!!
And on to the
Ive been wanting to build a roadster....
And then I canibolozed a piece from the mud pie SB and layed it on to give you guys an idea of where im going with it
Thats all for now
OHenry is offline   Reply With Quote
Old March 9th, 2014, 04:19 PM   #2
Thumbs up Re: Fresh Air project
That line from the SB really does look nice there. This going to be interesting. So is it going to have a top or are you just going to floor it when ever it starts raining
Old March 9th, 2014, 04:55 PM   #3
Default Re: Fresh Air project
Hey - you have it right - being a parent does slow things down a bit - but that is a good thing! It also makes everything so much better! Good for you!
As far as the build goes - I like it! Great use of the front cowl. I think this will be a fun one to watch.
And when Jeff chimes in about selling your kids - just tell him to go fall down a sand dune! He doesn't get it.
Old March 10th, 2014, 03:08 AM   #4
OHenry
OHenry's Avatar
Thanks guys! Of course I'm just going to just drive faster when it rains, isn't that what everyone does?
I plan on making some sort of soft top for it, but that will probably be towards the end.
After doing some digging it seems like the roadster that look "right" to me all use the sb cowl, (heb-roid) being the main one, but there quite a few others that have pulled it off well!
Hahaha selling the kid would probably move the project along faster time and money wise, but I think I'll keep him around. He can help with the next one that's due in September. And in a few years they can come help me built stuff
Old March 10th, 2014, 04:56 PM   #5
OHenry
OHenry's Avatar
Small update, snuck out to the garage for an hour or so and got a couple things started
First under the cancer vw foam I found a random chunk of wire harness that looks like it got very hot at one point, actually the shielding is melted
Then I started fitting part of the sb cowl.
So far so good, starting to think my vw is build with bondo and rust...or did they come from the factory like that
Old March 11th, 2014, 03:51 PM   #6
ChrisMac
ChrisMac's Avatar
liking this build a lot
In Maine, rust is original equipment!
ChrisMac is offline   Reply With Quote
Old March 11th, 2014, 04:21 PM   #7
BugTower
BugTower's Avatar
Likin' your plan... Very cool!
"I used ta do drugs... I mean I still do drugs, but I used ta to." Ricky, Trailer Park Boys
BugTower is offline   Reply With Quote
Old March 13th, 2014, 03:50 PM   #8
OHenry
OHenry's Avatar
Thanks guys!
Something I've been thinking is what kind of reinforcements should be adding?
I'd like to continue using the doors and still have access to where the rear seat used to be as I'm thinking that's where I'm going to put the air tank and compressor.
Suggestions and examples appreciated.
Old March 18th, 2014, 10:42 AM   #9
PAPA_SMURF
PAPA_SMURF's Avatar
Looking good...
If you want an easy way to do the radius behind the back seat use the top of the windshield frame you cut off. It will look really good and add structure. You have to widen it a couple inches but can be done with some conduit or schedule pipe. If you use conduit sand of all the galvanized shit with a flap wheel. when you weld that shit it is extremely toxic and can get you hella sick if you breathe it in. As far as structure study how vw did it on convertibles. You can get it nice and stiff and people will never be able to see where you did it.
...Joey
66 schwinn, 04 Jetta
vwclubofhawaii.ning.com
Old March 18th, 2014, 02:40 PM   #10
OHenry
OHenry's Avatar
Originally Posted by PAPA_SMURF View Post
Looking good...
Thanks for the ideas Papa, I have been checking out the verts and I'm going to try and emulate them as close as possible.
Small update, more patch work done
I think ill try your idea papa for blending it back into the body.
Scored a nice standard hood to sacrifice for the rear cover at the local yard for $30
Old March 18th, 2014, 03:55 PM   #11
1jarhead2
1jarhead2's Avatar
I thought for a minute that you were going to build a stoll coupe.lol. I too used a hood for the back deck lid on my roadster. I put a slice down the middle and stretched three inches at the top which I also cut straight across. She is looking good and hope to se here when she is done.
Old March 18th, 2014, 03:59 PM   #12
1jarhead2
1jarhead2's Avatar
Old March 18th, 2014, 04:12 PM   #13
OHenry
OHenry's Avatar
That thing is gorgeous! It looks like I'm going to have to widen it up a little, but I think I'm going to attempt combinding the top half of the hood with the deck lid... Some how
Old March 18th, 2014, 08:36 PM   #14
markh
markh's Avatar
It's possible to join the two parts.
Using even more front hood like you have planned, the more natural curve you'll get before it transitions to the rear deck lid.
Look forward to seeing what you do. Keep it up
Old March 19th, 2014, 03:01 AM   #15
OHenry
OHenry's Avatar
Thanks for the pics Mark and the encouragement, That helps me visualize where I have to go with it.
Old March 19th, 2014, 06:53 AM   #16
1jarhead2
1jarhead2's Avatar
Mark,I have never seen that coupe. That is slick.
Old April 9th, 2014, 04:35 PM   #17
OHenry
OHenry's Avatar
Small update, been busy finishing the kids rocking iron horse and trying to figure out the job situation the roadster has taken a back seat. Went out tonight and separated the body from the pan so I can see how much needs to be patched and start to work on the frame for the rear bags.
Old July 5th, 2014, 08:45 AM   #18
OHenry
OHenry's Avatar
I love when I type a big long post and the website deletes half of it!
Anyway small update since its been awhile.
Got the floor pans tore off, literally only had to lean on them and they came right off.
Then flipped the control arms, cut the shock towers off the pan, and installed pacific coast customs hiem joint spring plates, which I will say required a large amount of machining to even become usable. Installed the front airshocks, and will be doing a cantilever setup for the rear once the plates get water jetted at work.
Been playing with the idea of using the 32 grill again also
And since most of us here like making stuff, I figured I share some of the stuff I've been designing/ machining at work.
Old July 5th, 2014, 09:05 AM   #19
chris shu
chris shu's Avatar
hood and decklid combined
flat blacklaid back
chris shu is offline   Reply With Quote
Old July 11th, 2014, 10:30 AM   #20
OHenry
OHenry's Avatar
Update
Got the stuff cut out on the water jet this week, as so far its looking pretty good for the cantilever setup. I have to tweak the control arm mounting position a little but for the most part it looks like it'll work!!!
Pics of course sorry for the poor quality
Down
And UP!
Old July 11th, 2014, 02:23 PM   #21
BrownBUGUK
BrownBUGUK's Avatar
This is such a cool project.....puts my efforts to shame. I'll be watching your progress fella. Good luck.
BrownBUGUK is offline   Reply With Quote
Old July 11th, 2014, 02:39 PM   #22
Crazy_C
Crazy_C's Avatar
Definitely loving how this is coming along. Looking forwards to seeing it done! Keep it up man!
If you're a fierce individualist who has a bone to pick with the profit driven world, you might be a rodder.
Rodding is a mindset.
Crazy_C is offline   Reply With Quote
Old July 12th, 2014, 11:28 AM   #23
That is so cool. You are going to have them show, right?
Old July 12th, 2014, 11:40 AM   #24
chris shu
chris shu's Avatar
it would be a shame to hide them
flat blacklaid back
Old July 12th, 2014, 06:42 PM   #25
OB'S Customs
OB'S Customs's Avatar
Digging it!
Built not bought...
OB'S Customs is offline   Reply With Quote
