Members: 17,604
Threads: 32,290
Total Online: 463
Newest Member: smoknjoe
- by Vrshack
- by bugwhat
Old June 12th, 2014, 02:47 AM   #1
roc
roc's Avatar
Default LED rear lights | help needed!!
Hi,
Forgive me for I am a total newbie to anything VW related, I have my front lights fitted and ready to go, I bought LED lights for the rear an can't seem to get them working, do I need a certain amp, relay or converter???
roc is offline   Reply With Quote
Old June 12th, 2014, 10:03 AM   #2
Spanish Flea
Spanish Flea's Avatar
Default Re: LED rear lights | help needed!!
One thing you will need to replace is the flasher. LED's don't put the load on it to make it trip. Upgrade to a digital flasher.
Just my $.02 on the situation.
Spanish Flea
Spanish Flea is offline   Reply With Quote
Old June 13th, 2014, 08:43 AM   #3
roc
roc's Avatar
Cool thanks guys!
Old June 15th, 2014, 09:46 AM   #4
If I'm not mistaken, you just need to put a resistor on the circuit... Check google, I think this has been covered here before and I KNOW it's been covered millions of times before on the internet...
Old June 15th, 2014, 10:49 AM   #5
capt.funn
A trailer 7 to five wire converter is at NAPA for about 14.00 All input and output wires are marked and it is super simple. Did mine with LED s and took about five minutes.
capt.funn is offline   Reply With Quote
Old June 17th, 2014, 03:25 AM   #6
Vrshack
Vrshack's Avatar
Here is a pic of mine. Im using the led strips you can get them at Autozone or just about any where now.
jeff
Vrshack is offline   Reply With Quote
Old June 18th, 2014, 01:51 PM   #7
roc
roc's Avatar
Whoa!! That's a beautiful machine man!
Old June 18th, 2014, 02:35 PM   #8
The trailer adapter is only needed if you are using dual filament bulbs to act as brakes and turns.. If you still have the same number of sockets/bulbs but are just going to use led bulbs, you just need a resistor on the line to draw enough power for the relays to trigger properly.
Seriously if you check google you'll find tons of how tos...
Old June 18th, 2014, 02:38 PM   #9
http://bit.ly/UNoDC2
Old June 18th, 2014, 08:46 PM   #10
Will a digital flasher work with conventional lights? On my sidecar rig I have a bulb type t/s light in the back and an LED up front. This is only on the sidecar side. Sometimes the signals flash and sometimes not. The left side are stock Yamaha and work fine.
