Members: 17,343
Threads: 32,253
Total Online: 549
Newest Member: adnan
- by AMMO22
Old June 23rd, 2014, 06:59 AM   #1
bowtietrks2
Default Custom Glass
Am building a custom pick-up, need to cut down the rear glass to fit modified opening, can i get the original glass cut to fit ? if so where, i am located in Virginia.?
bowtietrks2 is offline   Reply With Quote
Old June 23rd, 2014, 07:06 AM   #2
Thunder938
Default Re: Custom Glass
Tempered glass, good luck. Some people say it can be done, but have never seen it done. I had the same problem with the rear glass of my chop..went plastic. If your rear glass is flat then just get new safety glass (laminated) that you can cut or get made to your temp. cheap.
Old June 23rd, 2014, 07:26 AM   #3
bowtietrks2
No such luck, mine is curved...Really didnt want to go with lexan, or any plastic due to the results of sun and weather....Plus it will be urethaned in place
Old June 23rd, 2014, 09:56 AM   #4
BrownBUGUK
BrownBUGUK's Avatar
Like has been stated, toughened glass cannot be cut down. The best you could hope for is a small amount ground down, but the risk of breaking is high. Laminated flat glass can be cut to suit any use but can only be curved during manufacture.
I always thought the rule for roof chops is to have the glass already and form the body to suit.
Show us what ya got fella
BrownBUGUK is offline   Reply With Quote
Old June 23rd, 2014, 10:11 AM   #5
Curved rear window, in a pick up ?
Sounds interesting.
I think the convertable rear glass is laminated safety glass.
Old June 23rd, 2014, 11:19 AM   #6
bowtietrks2
This is a 2000 vw jetta wagon when i started, the rear window frame is from rear hatch of wagon , i like the form but after tacking in place find its too tall....http://s714.photobucket.com/user/bow...?sort=3&page=1
Old June 23rd, 2014, 11:32 AM   #7
bowtietrks2
Am using bed floor and bulk head from 2000 s-10 truck bed, have new metal broke for the sides, using trailer fenders to dress out the stock mismatched ones, will modify lower half of original rear hatch for tail gate.....Every other pickup build ive seen has flat glass, and a flat rear cab, mine will be rounded to match the styling of the car........
Old June 23rd, 2014, 11:37 AM   #8
Consider using the windshield from something,
and cutting it down to get what you need.
Old June 23rd, 2014, 12:26 PM   #9
bowtietrks2
No i hadnt , but thanks ,i'll look into that option
Old June 23rd, 2014, 02:21 PM   #10
bdouglas
Read through this :
http://www.volksrods.com/forum/showthread.php?t=30052
another:
http://www.route66hotrodhigh.com/Glass.html
Brett
bdouglas is offline   Reply With Quote
Old June 23rd, 2014, 03:49 PM   #11
Those links are very helpful.
Old June 23rd, 2014, 06:28 PM   #12
bowtietrks2
what about setting it at the original angle, slant back style?
if you look at pics, the window opening is too tall, dips 1 1/2 below top of bed line , original glass measures 19 in tall.
Old June 23rd, 2014, 08:15 PM   #13
theglassman
Look around at the newer cars and suv's with the full sun roofs...."panaramic roof .........
You can get the glass panels sometimes when the dealer has to warrenty the mechanism........i have a few stashed away for that very reason..........you need to get friendly with a bodyshop guy or glass guy
walk a mile in someone elses shoes. then you'll be a mile away and have their shoes
theglassman is offline   Reply With Quote
Old June 24th, 2014, 03:23 AM   #14
bowtietrks2
It will be off to three different junk yards this week-end, like the windsheild idea, will have tape measure and cordless sawzall in hand.....
Old June 24th, 2014, 03:28 AM   #15
bowtietrks2
Checked out your truck build, very cool. It will be the new VW Caddy, pull it off right and you will confuse the shit out of people.
Thats my goal , will keep vw badges on grill and tail gate, also the reason i'm taking my time with the inside of bed area, and using truck bed floor metal, when finished it will be lowered on custom wheels n tires, i am keeping the sun roof we recently modified the switch to where it will tilt open only...want it to appear to be a factory truck..........
Old July 8th, 2014, 10:37 AM   #16
bowtietrks2
Found new rear glass at junk yard , smaller but this one has a fiberglass frame , need suggestions on epoxy to use to bond to cab sheet metal
Old July 8th, 2014, 10:40 AM   #17
bowtietrks2
Can see pics on my page, i taped it up over old idea for window ..????
http://s714.photobucket.com/user/bow...rganize&page=1
Old July 8th, 2014, 11:57 AM   #18
Shorter window looks better.
Good luck with the bonding.
Old July 10th, 2014, 09:06 AM   #19
Cut the fiberglass frame off and make another one (opening) out of metal. It will be better in the long run.
Old July 15th, 2014, 02:56 AM   #20
bowtietrks2
Yes you are correct, thats the route i'm taking, gunna start cutting old frame to shorten and widen to fit this glass, luckily it is only beutle so its soft and easy to remove. Will use urethane to install when finished.
