Members: 17,425
Threads: 32,269
Total Online: 524
Newest Member: leboo0jamesi
Old November 29th, 2014, 12:07 PM   #1
V8 VolksRod
V8 VolksRod's Avatar
Default V8 Volksrod Chassis
Re:: finishing it up
[IMG]IMAG0541 by Ben Modified, on Flickr[/IMG]
Old November 29th, 2014, 12:34 PM   #2
wvobug
Default Re: V8 Volksrod Chassis
Looking good!
wvobug is offline   Reply With Quote
Old November 29th, 2014, 01:09 PM   #3
Nice to see another take on a V8 VW. Checked out your blog, the electric bus is very cool. What sort of range does she have?
Old November 29th, 2014, 02:54 PM   #4
Ohoooooo Yeah ! Looks wicked !
Old November 29th, 2014, 10:11 PM   #5
I'm getting a fiat gasser vibe here. And thats pretty badass.
Old November 30th, 2014, 03:43 AM   #6
V8 VolksRod
Thanks. Range is at least 35 miles, about twice what I need on a daily basis.
Old November 30th, 2014, 05:37 AM   #7
Nice
Brings a tears to my eyes
Old November 30th, 2014, 05:03 PM   #8
crack monkey
crack monkey's Avatar
The v8 is fun but I too am loving the electric stuff.
We will have to chat sometime about the Toyota van. I am (when I have a garage again) building a solar charged buggy.
Old December 24th, 2014, 07:55 AM   #9
38Chevy454
38Chevy454's Avatar
Curious if you are going to have an X-member or anything tying the two sides together? That seems like it will have almost no torsional stiffness between the two sides of the frame. Each side is plenty stiff, but they are not linked to prevent twisting, best that I can see?
Old December 24th, 2014, 05:04 PM   #10
V8 VolksRod
Yes, other than the existing far front and rear connections there is a substantial drive shaft hoop and much larger transmission crossmember which i have yet to weld in. There is also a full cage which is made but not yet welded in. The cage also has several connections to the body and the body has some other stiffening already added in as well.
www.BenModified.com
Old February 10th, 2015, 03:05 PM   #11
V8 VolksRod
The V8 Bug body had to go back to the sandblaster as they missed some key areas. Six weeks later, still sitting there. On the bright side, In the meantime, I have pieced everything together to replace the automatic with a 5 speed!
Old August 28th, 2015, 09:48 AM   #12
V8 VolksRod
It is back from the Sandblaster!!
The Build so far...11 Build Videos here:
https://www.youtube.com/playlist?lis...h8VZOV52aD9irG
Old August 28th, 2015, 11:06 AM   #13
psychopork
psychopork's Avatar
Nice!
Thanx psycopiglet,
Old August 28th, 2015, 11:20 AM   #14
70 Bug Mid Engine
70 Bug Mid Engine's Avatar
Looking good! I have always been curious to see how much foot room you have once the trans tunnel is in. I mean a standard Bug doesn't have a ton of room how it is but add in a V8 with a trans tunnel... Any pictures of the pedal setup or foot room? I would like to do a front engine setup in my next Bug but with a 4 cylinder.
70 Bug Mid Engine is offline   Reply With Quote
Old September 1st, 2015, 03:54 PM   #15
V8 VolksRod
There is a good bit of legroom. I installed a bench seat. It sits just a few inches back from the original location. I will takes some photos when I get it back together.
Old January 15th, 2016, 06:04 PM   #16
Her stance and wheel base reminds me of an old double 'A' Fuel Altered.
Old January 16th, 2016, 12:06 PM   #17
X's 2
I love it
I'll say it again, except this time I'm gonna follow thru since I almost have my workshop cleaned up, this summer I'm getting back to work on my V8 Bug aka "The BitchN Bug"
It bothers me to walk past her every time I walk back to my workshop & not being able to get it inside
Old July 13th, 2016, 04:56 PM   #18
V8 VolksRod
So the photo site that I have been using is no longer and my photo links no longer work......so I am reposting the photos in bulk here.
[IMG]20141216_164959 by Ben Modified, on Flickr[/IMG]
[IMG]20160114_174332 by Ben Modified, on Flickr[/IMG]
New firewall
[IMG]IMAG0592 by Ben Modified, on Flickr[/IMG]
[IMG]IMAG0591 by Ben Modified, on Flickr[/IMG]
[IMG]IMAG0594 by Ben Modified, on Flickr[/IMG]
[IMG]IMAG0596 by Ben Modified, on Flickr[/IMG]
[IMG]IMAG0612 by Ben Modified, on Flickr[/IMG]
[IMG]20160713_164753 by Ben Modified, on Flickr[/IMG]
[IMG]20160713_164823 by Ben Modified, on Flickr[/IMG]
[IMG]20160720_150040 by Ben Modified, on Flickr[/IMG]
Swapped in a 5 speed
[IMG]20160720_150055 by Ben Modified, on Flickr[/IMG]
[IMG]20160808_124338 by Ben Modified, on Flickr[/IMG]
[IMG]20160810_172035 by Ben Modified, on Flickr[/IMG]
[IMG]20160805_135846 by Ben Modified, on Flickr[/IMG]
http://www.BenModified.com
Old July 17th, 2016, 03:36 PM   #19
V8 VolksRod
Part 12 in the Video Build Series:
https://www.youtube.com/watch?v=RLvjMUYjIXU
Old July 19th, 2016, 07:09 PM   #20
crack monkey
Nice!
Old July 22nd, 2016, 04:56 AM   #21
V8 VolksRod
Part 13 of the Build
https://www.youtube.com/watch?v=D9ALh3gIekE
Old July 23rd, 2016, 01:52 PM   #22
Looking pretty racy !
Old August 11th, 2016, 01:55 PM   #23
V8 VolksRod
Fought with the clutch slave cylinder today, but finally got it in. The cylinder is off a jeep cj5. It fit nicely next to the oil filter on the chevy V8 but the filter must be removed to get the bolts in. Bolted it up only to find that the filter was making contact with the bolt heads and would not screw on. Solved the problem with these button head bolts.
[IMG]20160811_101808 by Ben Modified, on Flickr[/IMG]
[IMG]20160811_101921 by Ben Modified, on Flickr[/IMG]
Prior to installing the hydraulic line to the clutch, I sleeved it with some heat shield.
[IMG]20160811_110427 by Ben Modified, on Flickr[/IMG]
I am re-purposed the back bone from the original vw pan. The section was originally fully enclosed but I have cut out the bottom panel and am using it as a driveshaft tunnel.
[IMG]20160811_105725 by Ben Modified, on Flickr[/IMG]
Old August 15th, 2016, 02:19 PM   #24
V8 VolksRod
Had to re-work the headers to fit the new engine position.
[IMG]20160811_102057 by Ben Modified, on Flickr[/IMG]
[IMG]20160815_150754 by Ben Modified, on Flickr[/IMG]
[IMG]20160815_150838 by Ben Modified, on Flickr[/IMG]
[IMG]20160815_150850 by Ben Modified, on Flickr[/IMG]
Old August 16th, 2016, 06:00 AM   #25
Do like the way this critter looks !
