Members: 17,695
Threads: 32,301
Total Online: 424
Newest Member: Rdelectric
Old January 25th, 2015, 12:50 PM   #1
V8 VolksRod
V8 VolksRod's Avatar
Default Volksrod Recipe
1 Rotten 61 Single Cab
1 400 HP ZZ5 Crate Engine
1 Hughes Performance Powerglide
1 Salvage Ford Explorer 8.8" Traction Lok Rear Axle
1 Stainless Steel Street Rod Front Suspension
2 Ridiculously Large Rear Wheels and Tires
2 Normal Size Front Wheels and Tires
40 Feet of 2x3 Rectangular 3/16" Wall Tubing
100 Feet of Welding Wire
Simmer over a hot Mig Welder for 6 to 12 months
A few more photos here:
http://www.BenModified.com
Old January 25th, 2015, 01:48 PM   #2
Default Re: Volksrod Recipe
looka does parts next then Concept sounds quite interesting. Keep the info and pics coming !!
Old January 25th, 2015, 04:45 PM   #3
I was wondering about where the engine was going, (sorta mid-engine, right?) what with that short wheelbase until I checked out 'BenModified.' I love the dropped front axle waay out front! Is the radiator 'gonna out front too?
Old January 26th, 2015, 06:45 AM   #4
theredbarn
theredbarn's Avatar
That's going to be as much fun to watch as Mark's cab-over!
Old January 26th, 2015, 06:54 AM   #5
That's gonna be cool. I don't see wheelie bars on that list. Lol
Old January 26th, 2015, 03:12 PM   #6
V8 VolksRod
Good Catch!
Old January 26th, 2015, 03:15 PM   #7
V8 VolksRod
Thanks. I haven't commited to a location on the radiator yet. it can go under the bed for sure, but something up front may work also.
Old January 27th, 2015, 06:48 AM   #8
How 'bout up front with a cut-down Splitty nose piece to frame it?
Old January 27th, 2015, 03:45 PM   #9
V8 VolksRod
That could work
Old January 27th, 2015, 04:41 PM   #10
V8 VolksRod
Todays Progress:
The crate motor came with a serpentine belt system and all of the common accessories. Removing the power steering pump will disrupt the layout, so I was going to make an idler pulley to replace the pump. Decided instead to remove the blades from the impeller and keep the pump. It was quick, easy and free. Now that there is no pressure, I connected the two hoses together and filled it with fluid to keep the impeller bushing lubricated.
Also laid out the truck with the dimensions that I have in mind
The truck will be set up with an engine cradle which with will allow the engine, trans and rearend to move as a single unit, similar to my V8 Daihatsu (photos) which will allow me to keep the wheelbase reasonable.
The Powerglide Shorty trans is intended for a hard tail rear axle as it can only accommodate 2" of yoke, so the engine cradle will work well. Here is the driveshaft/coupler with shortened yoke. The yoke will only move in response to engine/trans mount flex.
My Build Blog:
www.BenModified.com
Old January 28th, 2015, 09:35 AM   #11
I'm starting to drool on the keyboard
Old January 29th, 2015, 07:00 PM   #12
V8 VolksRod
The polished stainless steel tube axle front end arrived today.
Build Blog:
Old January 29th, 2015, 08:41 PM   #13
Very trick project. Are you going to fill in the wheel wells under the cab doors? Although they sort of make the cab.
Old January 30th, 2015, 02:52 AM   #14
V8 VolksRod
The floor and the bottoms of the doors and the dog legs are mostly rusted away and will be cut out. A new custom raised floor will be installed to fit the new frame rails, so a good bit of the wheel wells are going away anyway and the rest filled in. Crappy altered photo below.
Old January 30th, 2015, 09:47 AM   #15
V8 VolksRod
Old January 30th, 2015, 10:28 AM   #16
72 Squareback
Old January 30th, 2015, 03:05 PM   #17
V8 VolksRod
Old January 30th, 2015, 03:09 PM   #18
V8 VolksRod
Put the engine/trans in place and connected to rear axle. Ready to start on the Frame
Old January 30th, 2015, 04:49 PM   #19
Oh yeah!
Old January 31st, 2015, 05:18 AM   #20
V8 VolksRod
Video of the Build so far
https://www.youtube.com/watch?v=uT4ssjGdmbg
Old January 31st, 2015, 05:41 AM   #21
Very interesting~
Old January 31st, 2015, 09:34 AM   #22
sandman
sandman's Avatar
What Fun! Keep those pictures coming...This is Great!
Old January 31st, 2015, 02:03 PM   #23
V8 VolksRod
Started assembling the front suspension brakes and steering. Also started taking measurements for the frame build.
Old January 31st, 2015, 04:34 PM   #24
OKpig
OKpig's Avatar
Great project love the thought.......keep whacking at it.........
Pig is Me
Old February 3rd, 2015, 03:31 PM   #25
V8 VolksRod
Started on the frame today. Got one Z'ed rail done.
