Members: 17,519
Threads: 32,252
Total Online: 579
Newest Member: vw67
Old January 4th, 2016, 06:36 AM   #1
bogai
bogai's Avatar
Default If you have air ride I have a question for you
On my air ride system I run a small compressor that feeds two 15 gallon tanks. My problem is I keep getting leaks on the hose where it connects to the compressor as the little guy gets pretty hot. I now want to install a second compressor but want to know what hose is working best for those of you with air ride. Currently I have a two foot long steal braided hose, it is a little old so maybe this is the best thing just needs to be replaced. When I have tried other types of plain old air compressor hose cut to size with added fitting, they always blow off after getting hot.
Any suggestions/recommendations are appreciated as well as where to purchase.
65 ghia- bagged,chopped,oval window,suicide doors,tubbed,bug headlights,right-hand drive,59 caddy taillights,1.9 turbo, and much more
bogai is offline   Reply With Quote
Old January 4th, 2016, 02:39 PM   #2
Default Re: If you have air ride I have a question for you
This is what I ran for all those miles. The compressor to tank never leaked.
72 Squareback
Old January 4th, 2016, 02:57 PM   #3
Any chance the compressor is on the small side,
and 30 gallons is a lot to fill, so the compressor runs too long ?
Old January 4th, 2016, 03:06 PM   #4
bogai
bogai's Avatar
Yes, on the small side. So I now have a second to run with it, but need a hose for it as well. So figured I would see what works best for those of you who have done it before.
Old January 4th, 2016, 03:18 PM   #5
I had around 40k miles worth of compressor use with that set up before i sold the car.
72 Squareback
Old January 4th, 2016, 03:44 PM   #6
bogai
bogai's Avatar
Where did you purchase the parts?
Old January 5th, 2016, 05:51 AM   #7
lunatic_magnet
lunatic_magnet's Avatar
this is what my setup looks like. everything leaving the tank is 3/8 DOT air line and compression fittings. the red line from the compressor is just a push on fitting. hope it helps.
volksrods member #39
