Members: 17,345
Threads: 32,252
Total Online: 506
Newest Member: vw67
Old January 20th, 2016, 01:04 PM   #1
69satellite
Default Maybe mid-engine ghia
Been thinking on how I want to repower the 71 ghia we have. She is far from pristine so I could care less about fixing it back to stock. But I keep going back to transverse mounting a tdi in the back. With some mods you can get good power and awesome mpg out of it, especially in a light ghia. I have to fix the pans and heater channels anyways. I was planning on using tube for the outer perimeter of the frame, which also will let me drop the floor down alittle bit more so my head isn't so close to the roof. Thinking if you cut off the irs, so the pan is flush at the back, and weld on some 2x4 tubing in its place it give a good place to weld on rails (2x3) for the motor and trans. Some 1x1 for cross support for the seats. I'd want to use the stock subframe so I can just bolt it/out the whole assembly. Use the hubs and all, just use a piece of tubing with heim joints to keep the wheels straight. If I go this route I'd buy a donor car, also probably take the seats, steering column, and other pieces the price of tdi cars are very reasonable if you aren't in a rush to buy one. So a couple locally that are under 1500 and run. Going have to be alittle bit before I have the money to buy the donor with the house remodeling we are doing. Here's a rough sketch of what I'm thinking. I don't have the frame dimensions for a mk4 VW so the rails may be the wrong angles but it gets the point across, and I used ms paint and I suck at drawing.
69satellite is offline   Reply With Quote
Old January 21st, 2016, 08:30 AM   #2
Default Re: Maybe mid-engine ghia
One thing to check is the track width as Ghia's don't usually have a ton of room in the rear wheel wells.
Old January 21st, 2016, 11:14 AM   #3
if you run short axles, you can get a 205/70/15 under the car. i know... i'm running a midengine type 3 with track issues as well.
72 Squareback
Old January 21st, 2016, 02:52 PM   #4
69satellite
I looked up the width on an mk4 jetta and its about 4in wider than the ghia. So about a 2in flare on the rear qtrs would take care of that. Also figured the wheel wells and most the metal in the engine bay would have to be cut out and redone once the drivetrain is in place. I see this working, fine in my head but then again I have been known to be wrong before.
Old January 21st, 2016, 04:26 PM   #5
Never being wrong just means you've never tried. Measure a lot and make lots of cardboard templates. Sounds like a cool project.
Old January 21st, 2016, 05:43 PM   #6
69satellite
Guess I must have tried alot over the years, lol. Anyone have dimensions on the tdi? I've been looking all over for the physical dimensions of the engine and can't find them anywhere. Only issue I see could be the height.
Old January 21st, 2016, 06:37 PM   #7
Check out the build by VR6 Notchback for info
http://volksrods.com/forum/showthrea...=VR6+notchback
Old January 22nd, 2016, 07:09 AM   #8
If you're not stuck on the "all VW" part of the plan, a mid mounted Subie would seem to be a great choice. Not sure how that would compare in the track width area, but it would be a nice package.
mkparker is online now   Reply With Quote
Old January 22nd, 2016, 02:22 PM   #9
69satellite
I actually have a ej22 sitting on the ground in the garage. I was originally planning on just using an adapter and use the ej22. But I really want to go tdi for the mpg and power they make. Tdi cars have come down alot in price these days compared to what they use to run for a used one.
Thanks for the link to the vr6notch. Simllilar to what I'm thinking on doing for the frame, except I don't want a cage.
And I just came across a guy over on shoptalk that did a vr6 in a ghia, so nice to see it will work like I was thinking.
Old January 22nd, 2016, 02:42 PM   #10
69satellite
http://s847.photobucket.com/user/Ghi...tml?sort=6&o=0
Old January 22nd, 2016, 04:37 PM   #11
I could design an a-arm setup for the rear pretty easily, especially if you were going stock VW tranny. If you ran a Subie engine/ trans combo and locked out the AWD end; as long as I had a few specific dimensions, I could draft something up.
Old January 23rd, 2016, 08:11 PM   #12
69satellite
Thanks for the offer. But I think I want to go transverse tdi. Wish I had some spare money right now because I saw a couple good deal on tdi cars but all the money is going into the house right now.
Old January 26th, 2016, 06:07 PM   #13
69satellite
Got to think on this. Ej22 would give alot more room to work on than the transverse setup for sure. Here's pics of the vr6 in a ghia.
Old January 27th, 2016, 12:59 AM   #14
But if you kept the VIN plate and back of the pans where they are, the engine and trans will get pushed back and your CV joints may be taxed a bit.
Old January 27th, 2016, 09:20 AM   #15
Back when I designed fire engines and space and angles were tight for the pumps, an engineer from Spicer told me that 11degrees was the max for u-joint and CV joints. This would be at the maximum deflection with, in your case the suspensions ups and downs, not static.
When I ran a '65 Corvair powertrain and full IRS in the Single Cab, I'd used ten degrees static (the SC at rest). With the suspension changes and daily driving I went through U-joints about every 500 miles. I'd hear a "clicking ' sound from the back end and they would be going...I used the SC as a truck and had the back end up for clearance. At the time I wanted her to sit high and level.
Old January 27th, 2016, 09:37 AM   #16
You can go up to 28* with race prepped 930s but not as a constant. I have my 930s running at 11-16* for my designs.
