Members: 17,610
Threads: 32,290
Total Online: 516
Newest Member: acepilot
- by Vrshack
- by bugwhat
Old January 20th, 2016, 07:07 PM   #1
sloppyjoe
Default Trying to Run Big Tires
I want to run big tires on the front and rear of my volksrod. If I could fit 40's I would be stoked, but I know even a 35" tire is going to be pushing it. I think I have the rear figured out with an air ride setup that will use air bags not air shocks. The front has me a little stumped. I want to use a vw beam and an extender, just not sure if I can get it low enough. I want the bug to still sit low to the ground, like 4" of ground clearance. I will be running drop spindles, and 4" of drop in the beam, but how else can I get the front end down? If I add adjusters to the beam, how much will I be able to drop it with those? Is there anything else I can do to drop the front?
1958 VW Bug, Capella chop, 3 1/2" package tray raise
sloppyjoe is offline   Reply With Quote
Old January 20th, 2016, 07:57 PM   #2
Default Re: Trying to Run Big Tires
Raise the frame head.
Also, look at Redux boxes on back.
Old January 22nd, 2016, 06:14 AM   #3
With a 35" to 40" tall tire you're gonna have some issues if you don't raise the frame head considerably, as Unkl mentioned.
Old January 22nd, 2016, 07:40 AM   #4
get a custom built extender with more drop in it.
For a custom piece, it might be well worth will to get in touch with Doug (DBUG47) at the volksrod shop.
Old January 22nd, 2016, 09:00 PM   #5
sloppyjoe
I have started researching the frame head raise. That seems like the best solution for the front. I am planning on building some drop into the extender and will see if I can talk the guy into a coupe more inches. He will know what works and what doesn't, or at least what he is comfortable with.
Old January 23rd, 2016, 08:12 AM   #6
The more you raise the frame head,
the less room you have for an extension.
Because of the shape of the hood.
Old January 23rd, 2016, 09:40 PM   #7
sloppyjoe
Yeah, been thinking about how to work that out. I've got to talk to the fab guy, but can't I build some of the drop into each side of the extender? I know they will build drop into the extender on the side the beam attaches. But can I also add some lowering to the frame head side? I am just thinking about this while I research, and still need to look at some more threads about extenders. Just wondering if people have done that?
Old January 25th, 2016, 03:51 AM   #8
You can always cut out room for the tires on the sides, and put blisters on the hood to make room for the suspension mods underneath
Old January 25th, 2016, 02:29 PM   #9
Clearing the rear torsion bars/ end caps can get crazy too. If you run the long bars, most you can run is 31".
Old January 25th, 2016, 07:35 PM   #10
sloppyjoe
Yeah, the torsion bars are a concern on the rear. But I have a plan for those with a combo of wheel offset and wheel adapter, plus a custom air bag setup that will get me out past the torsion bars. I like the blister/bubble idea for the hood. Just need to make sure it looks clean, and not like an afterthought.
Old January 25th, 2016, 08:26 PM   #11
COULD "flip" the beam, to get more stretch.
Old January 30th, 2016, 03:24 PM   #12
That is going to be some major offset!
