Members: 17,522
Threads: 32,241
Total Online: 503
Newest Member: Harold
Old February 2nd, 2016, 06:56 PM   #1
flatheadgary
Default how does this work?
Re:: torque tool
ok guys, i have one of those torque dudes or torquemeister or whatever it's called. it works great on gland nuts but when i tried to use it on the wheel nut the gear just pops off the plate teeth.
full disclosure, i didn't get the long lug nuts that come with some of these and had to use long bolts. do you think the fact that i don't have the chamfer on the bolts is why it pops off? any other ideas? it's not something odd, just a '64 sedan. thanks in advance. gary
Last edited by flatheadgary; February 2nd, 2016 at 07:07 PM. Reason: forgot something
Old February 3rd, 2016, 01:00 PM   #2
Default Re: how does this work?
It could be from not having the correct bolts. If you could make a bushing to center the bolts, it would probably work on the axle nuts. I have had mine do the same it the bolts were not tight.
Old February 3rd, 2016, 09:09 PM   #3
flatheadgary
i am going to socal imports thursday and see if i can get the bolts. it's 2 hours away so i have to make time for the trip. thanks for the reply timbo.
Old February 17th, 2016, 04:50 PM   #4
Cat Box's Avatar
I am not certain of what you are having issue with...
Here is how mine worked on my axle nut when I redid my disks not that long ago.
