Members: 17,662
Threads: 32,333
Total Online: 566
Newest Member: msjohnston2000
- by butch27
Old November 5th, 2016, 03:03 PM   #51
Default Re: Obtaining my dream racer...
From my experience. There are those who have (screwed up), and those who will. Those who claim to have never 'screwed the pooch,' have either never built anything, or are not exactly telling the truth..
Old November 5th, 2016, 04:34 PM   #52
I'm wondering IF I can use a hydraulic jack or ram to flex the 2" box tubing that 1/2"?
72 Squareback
Old November 5th, 2016, 10:49 PM   #53
DAMMIT
Old November 6th, 2016, 07:03 AM   #54
I've used a standard 'comes-with-a-car scissors jack' to do things like this. A hydraulic jack, at least mine, doesn't work well on its side.
Old November 6th, 2016, 01:49 PM   #55
I have borrowed a body shop hydraulic ram today. I'm hoping I can flex the mount that 1/2" out at 16" without screwing everything up. If I do, I will be starting over. It's just time and money.
72 Squareback
Old November 6th, 2016, 07:39 PM   #56
I was able to flex/bend the mount the 1/2" over and 1/4" up. Tacked 3 welds on the cage base and releases all the pressure. It all held!
72 Squareback
Old November 7th, 2016, 05:01 PM   #57
Excellent! That's why it is said, "Woods good, glass is class, but steel is REAL."
Old January 5th, 2017, 09:32 PM   #58
Took it back apart today. Didn't like it. Rd 2 tomorrow.
72 Squareback
Old January 6th, 2017, 03:48 PM   #59
Need to do some more cutting before welding, but much happier so far.
72 Squareback
Old January 9th, 2017, 02:45 AM   #60
I never heard that saying before, I Like It
Everything works itself out in time, just go at it slowly, unless of coarse your in a hurry, then just take your time anyways
That almost reminded me of something WC Fields would say
Like his cure for insomnia..... Get plenty of sleep !
Old January 9th, 2017, 08:57 AM   #61
I can lay 10" of bead around each of the front mounts and 14" of bead around the rears. that should be plenty strong.
72 Squareback
Old January 9th, 2017, 03:13 PM   #62
Was the original based on a tube chassis, or a VW pan ?
Old January 9th, 2017, 04:07 PM   #63
Custom middy chassis. I can't go that route... Yet.
72 Squareback
Old January 9th, 2017, 04:41 PM   #64
Cool.
Old February 4th, 2017, 04:28 PM   #65
First chance to test fit the cage to the body to the chassis. I need to pull 1/2" from all four cage legs and the body to chassis height isn't set yet. So, the height of cage to body ratio is off a bit. But... The cage is 3" farther forward than I expected, which is good. Also, the chassis is at stock height so far.
I will mark cage position and disassemble again to do the next phase of welding.
72 Squareback
Old February 4th, 2017, 04:42 PM   #66
How much did the cage stick up on the original ?
Old February 4th, 2017, 06:40 PM   #67
Not as high, but it won't be as high when I'm done either.
72 Squareback
Old February 4th, 2017, 09:13 PM   #68
Glad to see that things fit. I just love those headlights.
Old February 5th, 2017, 10:37 AM   #69
The rear of the body will actually be 5-6" higher than in the picture and then the rear end will be lowered a couple inches until the body is 4" from the ground.
72 Squareback
Old February 5th, 2017, 01:16 PM   #70
Better perspective
72 Squareback
Old February 14th, 2017, 10:57 PM   #71
Almost the final body to pan placement. The rear will be 3" lowered into the body and the front will be 1.5" lower. Then, the entire car will still have to be lowered. Closer...
72 Squareback
Old February 15th, 2017, 10:03 AM   #72
Much better and looking good!
Old February 15th, 2017, 04:42 PM   #73
It's coming together & lookin good
Old February 19th, 2017, 03:49 PM   #74
Complete hault. Cage is in, body is on. Not enough clearance from helmet to main hoop. Not race legal. Can't afford to redo this thing. Garage art now. Oigh...
72 Squareback
Old February 19th, 2017, 04:33 PM   #75
Different (lower) seat ?
Different seat brackets ?
Lean the seat back ?
