Members: 17,512
Threads: 32,311
Total Online: 1465
Newest Member: Dantra
- by Zee
Old September 29th, 2016, 04:59 AM   #1
Amber 74
Default Proper Deck hight.
I'm reringing my 74 1600 dual port with stock size pistons and see in all how to build articles and videos to make sure and set proper deck hight but can't find what the proper specs are. What is the specs for this ? There were no shims under my jugs when I tore this engine down. Thank You .
Old September 29th, 2016, 07:47 AM   #2
Default Re: Proper Deck hight.
Measure what you have, IIRC, I think it should be around .040".
Old September 29th, 2016, 03:43 PM   #3
too much is a problem.
If the motor is stock, the easy answer, is assume the factory had a clue.
Old September 30th, 2016, 04:37 AM   #4
Amber 74
Motor has been rebuilt with 85.5 Mahle pistons. There were no shims under jugs. Pistons are being cleaned for reassembly to check what deck hight is now. was told to set hight at .125 to be safe. Is this too much ?
Old September 30th, 2016, 05:06 AM   #5
If it was running ok before the re-ring and all you did was replace the rings, I'd just put it back together. I'm no engine "builder" however.
Old September 30th, 2016, 07:57 AM   #6
.125" is WAY too much.
Old October 3rd, 2016, 04:40 AM   #7
Amber 74
Had a vw tech tell me .075. Not sure what to set it at. May wait on new stock heads and cc them.
Old October 3rd, 2016, 07:52 AM   #8
You're doing things the right way by asking questions and taking your time. Which, is turning you into an "engine builder."
Old October 5th, 2016, 07:25 AM   #9
Amber 74
I think I'll wait until I get new heads and cc them to be safe and ask again .
Old October 6th, 2016, 01:50 PM   #10
theredbarn
theredbarn's Avatar
CC your heads, and then do a compression calculation. Stock cam try to keep it at less than 7.5:1. With a 110 cam I lake to be at 8:1...
