Members: 17,525
Threads: 32,283
Total Online: 471
Newest Member: dave j
Old October 23rd, 2016, 05:21 PM   #1
Square
Square's Avatar
Default Butcher '70 Single Cab
Hey Y'all been a while
Finally have an air cooled again and it's a project and a half (pun intended)
This rare jewel is a hack job, 70 single cab front and deck, 73 engine and backend.....
Has a 1700cc awesome,
front and rear bolt patern is different okay needs work
Treasure chest has a slider rocker, neat oh, screams custom door
Low flashers up front, Big tails out back
Perfect volks rod project if you ask me.
Plan is to cut out the rust, weld it up and drive,
already had some shaming from the purest
File Type: jpg image.jpg (157 Bytes, 389 views)
Old October 23rd, 2016, 08:14 PM   #2
Default Re: Butcher '70 Single Cab
Needs pinstripes.
I know a guy.
Old October 23rd, 2016, 08:32 PM   #3
5 bolt drums, on a Bay ?
Hmmmmmmmmmmmmmmmmmm
I can hear the Purists now.
Old October 24th, 2016, 03:09 AM   #4
Square
Square's Avatar
Hmmmmmmmmmmmmmmmmmm
Hey Ian, no idea if the wide five will swap in, mite need a stub shaft too
Old October 24th, 2016, 05:14 AM   #5
Square
Square's Avatar
The samba bay disc conversion info and linky
http://www.thesamba.com/vw/forum/viewtopic.php?t=556325
Disclaimer.....Only the info I need is posted......
----OEM PARTS DISCRIPTION REAR
1968-70 Long Stub Axle 9.125”end to end. One piece hub and drum 5x205/ wide 5, 14x1.5mm lug bolts.
1971-91 Short Stub Axle 8.25”end to end. Hub and drum two piece 5x112/narrow 5, 14x1.5mm lug nuts.
1968-91 Inner Axle Bearing the same. The one closest to the C.V. joint.
1968-70 Outer Axle Bearing the same. The one closest to the brake drum.
1971-91 Outer Axle Bearing the same. The one closest to the brake drum.
1968-91 Inner & Outer Seals the same.
1971-79 Rear hubs the same.
1968-91 Axle Nut the same.
1968-70 Brake Drums the same 5x205/ wide 5 pattern.
1971-79 Brake Drums the same 5x112/ narrow 5 pattern.
1973-79 Multiple year brake shoes 1/73 to 79. Backing plates the same.
Old October 24th, 2016, 11:36 AM   #6
ahawes
My 68 Bay had wide 5.
ahawes is offline   Reply With Quote
Old October 24th, 2016, 12:31 PM   #7
I think the 'wide five' ended with '68. Your Single Cab is 'gonna' rock. I've been told that mine is, "a travesty." I take it as a compliment.
Old October 24th, 2016, 12:52 PM   #8
Square
Square's Avatar
Thanks guys
I'm still on the fence 'chop' or 'no chop'
I want to get all the rust repair out of the way before doing any body line changes.
Old October 25th, 2016, 08:32 AM   #9
Dad had a 69 bay. 14" wide 5.
Old October 25th, 2016, 08:35 AM   #10
I'm no purist. Should classic cars be restored? Probably. But driven always trumps sitting in a field, garage, or museum.
Personally, if the thing is built right, and if not too valuable when started, do it. Cut it up. Drive it. Enjoy it.
Old October 25th, 2016, 09:04 AM   #11
Square
Square's Avatar
date code 11/69
Thanks
Old October 25th, 2016, 10:27 AM   #12
So the back end is from a later Bus ?
Weird.
Old October 25th, 2016, 03:15 PM   #13
Wonder if it got into an accident or something? Because I see orange paint everywhere and it looks like somebody took a 1973 bus that might have been flipped wrecked or what not and then trimmed it and slid it underneath the messed up section of the 1970. I wonder if they just simply swapped the beam in the front then? I know little about buses but that's what it looks like to me.
Old October 25th, 2016, 03:58 PM   #14
Square
Square's Avatar
Yes back end bus, front end single cab
Very awesome! I think it's just a rust repair
But don't have the full store yet
Lots of rivets, the deck was cut off with 2" of steel below then riveted on to the bus
Most of the bondo has fallen off so it makes it easy for me to drill them out
I have a frame section coming from Colorado, so just pulling parts off and making some beadroller dies (floor and deck profile) until them
Here is YouTube walk around
https://youtu.be/QgRLAmnElyI
Old October 25th, 2016, 05:15 PM   #15
Any plans for a crazy engine swap? After hearing what one member did here with a transporter I've liked the idea of mid engine ford power
Old October 25th, 2016, 07:13 PM   #16
Square
Square's Avatar
Saw it on FB, Just want to drive it For Now
Old October 30th, 2016, 06:04 AM   #17
Square
Square's Avatar
I'v got a frame section coming from Colorado, that's all the updates from now.
Going to pull the doors and any other large parts and bring them home to work on in my garage, the single cab is in storage for the winter, it's close to my house but not that close.
And funds have run out until I get some of the Pinstriping and Sign work finished that I have on the go... so I better get to it....
Old October 30th, 2016, 12:31 PM   #18
Is it done yet ?
Old October 31st, 2016, 03:37 AM   #19
Square
Square's Avatar
Coming from Colorado to Canada eh? That sounds $$$
Nope it's about the same cost if I have the steel cut with two bends.
Shipping via Greyhound and I still have to crossover to pick it up
But way less work in fitment
Old November 13th, 2016, 06:11 AM   #20
Square
Square's Avatar
Hey Volksrodders, hoping I can get so help??
I need the louver measurements of a 68 to 79.
Both treasure chest and engine bay.
I have none,
Thanks
Old November 13th, 2016, 07:03 AM   #21
There's a guy running around in my area with a tan Single Cab of that vintage. I'll see what I can do.
Old November 16th, 2016, 09:36 AM   #22
Square
Square's Avatar
Frame rail is here!!! shipped via Greyhound, Colorado to Buffalo NY.
I'm in Canada and woke at 4am this morning (I never get up that early) drove and drove and drove, crossed the Canadian/US border Grayhound was 10 minute drive state side
Walked into Greyhound to picked up my very long piece of frame rail and they tried to give me a Bumper! I declined. "same length" I told them, "but flat".
SO here I am walking through the bus terminal with what looks like a large rifle...
No, its not done yet... I like to collect parts first.
Old November 16th, 2016, 10:53 AM   #23
How about now ?
Is it done yet ?
Old February 2nd, 2017, 08:22 AM   #24
Square
Square's Avatar
Still collecting parts and saving $$$ for more parts.
I have most of the small stuff, Big stuff needed are the windshield and drivers door window crank, up and down long channel thingy (I thought that there would be a repair kit for this?? just the rope with beads, simple right! I remember years ago 20+ repairing a Cadillac power antenna and the kit was a plastic rope with the antenna attached it was super easy to install)
OH and the big one! found the 9 louver side vents in the UK for a reasonable price!
just going to cut and weld them in.
no pics just a brain dump.
Old February 2nd, 2017, 08:43 AM   #25
Saw someone on FB, with windshields in Cinci.
New repops.
singlecab
