Members: 17,688
Threads: 32,298
Total Online: 136
Newest Member: gstong
- by Frank3
Old March 11th, 2017, 08:54 PM   #1
Default Look what followed me home yesterday...
It will need an altitude adjustment, but it is rust free and clean!
72 Squareback
Old March 12th, 2017, 05:20 AM   #2
Default Re: Look what followed me home yesterday...
That looks clean
Old March 12th, 2017, 06:50 AM   #3
Looks to be missing the usual bad rustout ?
Old March 12th, 2017, 09:39 AM   #4
YOU SUCK! I want one of those!!!!!!!:thumbsu p:
Old March 12th, 2017, 10:53 AM   #5
No rust...10ft paint and no interior issues really. Clean car, just needs an altitude adjustment, wheels and the correct carbs...
72 Squareback
Old March 12th, 2017, 12:33 PM   #6
No rust? Darn, looks like time to have my lap top checked over.....
Old March 12th, 2017, 04:31 PM   #7
Stupid, stupid idiot PPO! The carb's electric choke wasn't hooked up AND it was set to almost full closed all the time. DOH!
To top it off, the choke screws were so tight, i destroyed them to get them loose enough to adjust them. Finally got it set up so that the chokes go from closed to open in about 40 seconds. Warm idle is about 900rpm.
Runs better now, but OH MY HECK!
I need to find some dual carbs. The PPO removed all the FI stuff, including the wiring harness/brain. So, carbs...
Anyone have a set of ICTs/linkage/cleaners they would part with?
72 Squareback
Old March 12th, 2017, 05:47 PM   #8
WOW NICE SCORE !!!
I've ALWAY disarmed the electric chokes & set them wide open on every VW I've owned since reading the book "How to Keep Your VW Alive" back in 1981 (my dad bought it for me as a Christmas gift after buying my first Bug at 15 years old), I didn't wanna take any chances after reading what John Muir had to say about them
It might take a bit longer to keep it running until it gets warmed up on the fridged cold Ohio winter days, but I'm ok with it, my ankle gets a lil sore, but I think of it as good physical therapy
Old March 12th, 2017, 10:15 PM   #9
I can't keep a VW running longer than 2 minutes...
Old March 12th, 2017, 10:53 PM   #10
theVman
theVman's Avatar
Lowered....
theVman is offline   Reply With Quote
Old March 13th, 2017, 03:37 AM   #11
kustomkreep86
kustomkreep86's Avatar
That's pretty rad! Good find. Can't believe how clean it is.
Build...Break...Fix...Repeat
Old March 13th, 2017, 08:30 AM   #12
Originally Posted by theVman View Post
Lowered....
that's the plan, plus black wheels, no caps and chrome lug nuts...
as to the electric chokes, I don't use them on dual carb cars (short runners) but this stupid center mount is temp fickle.
72 Squareback
Old March 13th, 2017, 09:40 AM   #13
I don't know if this is any help in your particular situation. In my Corvair powered '72 bug, I built a center mount manifold out of steel tubing for a Holly two barrel (with a cable choke) and initially had problems with the fuel delivery. On cool days the engine didn't run so well in the morning. But when the temp warmed up later in the day it seemed better, but not perfect. One morning when the engine was running rough, I noticed ice at the underside of the tubing beneath the carb. I ended up running a 1/4" copper tube from the exhaust on one side to the other, which I ran up against the underside of the manifold. I used a 1/4" fitting on one manifold and 1/8" or so on the other, the theory being that the hot gasses would flow across and heat the manifold. This worked and my problem with the carb ended.
Old March 13th, 2017, 09:55 AM   #14
Thanks V8. But, I am going to use duals so I can have the cargo floor useful again.
72 Squareback
Old March 14th, 2017, 04:02 PM   #15
Nice score. I've had a couple of Type 3's. Last one was a blue all original 73. Bought for $200.00/ Needed tires and a main seal. Lowered it and drove it.Always wanted a fastback.
Old March 24th, 2017, 06:45 PM   #16
have the duals, currently building the linkage for it (didn't come with any).
72 Squareback
Old April 1st, 2017, 05:59 PM   #17
A bit less clunky looking now!
72 Squareback
Old April 2nd, 2017, 05:55 AM   #18
Much better.
Old April 2nd, 2017, 09:03 AM   #19
72 Squareback
Old April 9th, 2017, 12:11 AM   #20
400+ mile round trip today. I think I know all I need to know about my car now! No radio, just the voices in my head and the sound of the engine. Oh, and that crappy carb getting 21.5 mpg. Doh!
Well, it was an eventful trip! Felt what seemed like I lost a weight or broke a belt in a tire. Then suddenly it was much worse. Got off the freeway in PDX (200 miles from home) just in time for it to separate!
Limped to a tire store (thanks GPS). The tire held air until I got there.
Tire shop tried to put 195/60s on the front and the best two of my 165s on the back. Doh!
Made it just in time to my destination to watch my youngest dance. After, I started the 200+ miles back... Wind, rain, hail and then a full moon kept me alert in the dark drive.
The headlamps are non H4s (until tomorrow) and barely light up the nigh vs modern headlamps. Top that with them not being aimed correctly. Oigh! Brakes need a bit more bleed and I have a nasty rattle coming from either the hinges for the rear seat back or somewhere from the engine/transmission and transmitting to the cab. That is ANNOYING!
72 Squareback
Old April 11th, 2017, 05:01 PM   #21
72 Squareback
Old April 11th, 2017, 07:54 PM   #22
Why does the wheelbase look a little short ?
Old April 11th, 2017, 08:25 PM   #23
front wheel is turned a touch. the rear end is too high... will sit more centered when i drop it.
72 Squareback
Old April 12th, 2017, 08:00 AM   #24
ok
Old April 12th, 2017, 08:57 AM   #25
Originally Posted by 1slo3 View Post
front wheel is turned a touch. the whole damn thing is too high... will almost lay rockers when i drop it.
There, fixed it for you buddy!
