Members: 17,715
Threads: 32,304
Total Online: 457
Newest Member: Jcowen
Old October 8th, 2017, 10:40 AM   #1
Amber 74
Default Valve guide lube.
Getting ready to reassemble my new heads after gasket port matching, polishing the combustion chambers and the exhaust ports and lapping the valves for a proper seat . The manual that I have says put white molybdenum - disulphide grease on the valve stems . The best I can find on this grease it seems to be an antiseize of some kind. Is this the best to use or is there something better to use .
Old October 8th, 2017, 10:43 AM   #2
Default Re: Valve guide lube.
You are overthinking this.
I use assembly lube if I have some.
I have also used plain old wheelbearing grease
Old October 8th, 2017, 12:23 PM   #3
^^ There you go. In the olden days wheel bearing grease was the number one choice when assembling an engine. And likely in a repackaged form, still is.
