| Stuff to check out... |
| Forum Stats |
Members: 14,577
Threads: 30,745
Total Online: 41
Newest Member: youngtimerfan
April 28th, 2012, 09:06 PM
#1351
Re: Type 3 VolksRod
Since I am now just waiting for the production hood ornaments, I figured I better get back out in the garage and work on the Sled. Spent a few hours Friday and Saturday working on the rear air ride stuff.
I started out welding a couple of old pieces of the rear load floor I had saved back together so I could have a better sense of the space available for the air ride system. I then bolted this to the rear subframe and flipped the whole thing upside down.
I then started out fitting a rectangular tube I had fabricated from two pieces of angle iron between the shock towers.
and then cutting and fitting the upper bag mounts....
Plan to get out there tomorrow and get some of this welded up and the lower mounts built.
At that point I can put the rear subframe back in the car. I plan to fabricate a couple of solid spacers to use instead of the bags for the remainder of the build. When it is ready for its first drive I will swap in the bags and pumps and tanks and stuff.
April 29th, 2012, 06:55 AM
#1352
Re: Type 3 VolksRod
Nice to see you get some time for the sled...Air ride is next on my list it would be so much easier if I got rid of the heat but I live in the PNW.
Built not bought...
April 29th, 2012, 06:56 PM
#1353
Re: Type 3 VolksRod
Good to see you back at it John!
April 30th, 2012, 06:37 PM
#1354
Re: Type 3 VolksRod
April 30th, 2012, 07:06 PM
#1355
Re: Type 3 VolksRod
Sweet.
April 30th, 2012, 07:10 PM
#1356
Re: Type 3 VolksRod
Looking good! Great to see the fab work.
April 30th, 2012, 07:19 PM
#1357
Re: Type 3 VolksRod
What was that line, from Airkwld, about "complex geometry" ?
May 4th, 2012, 09:13 AM
#1358
I didn't fucking break it
Re: Type 3 VolksRod
Is it done yet?
Originally Posted by Unkl Ian
May 13th, 2012, 08:15 PM
#1359
Re: Type 3 VolksRod
May 14th, 2012, 01:46 AM
#1360
Re: Type 3 VolksRod
John, get some sleep bro.
Pure awesomeness!
May 14th, 2012, 07:13 AM
#1361
Re: Type 3 VolksRod
Looks killer!! Cant wait for more!
May 14th, 2012, 08:35 PM
#1362
Re: Type 3 VolksRod
Awesome stuff bud!
May 27th, 2012, 11:21 PM
#1363
Re: Type 3 VolksRod
Over the last couple of days, I got some blocks cut to represent the airbags for the time being and decided to install the rear subframe to check fit and tire clearance.
Here is the subframe with the wooden blocks and sitting on some dollies to let me roll it into place.
Couple of pictures getting it into position under the car.
Got it all bolted up and installed the tires...
Plenty of room for the tires...
Not sure about changing a flat yet...will have to wait until I actually have the bags in to see how much clearance I have with the bags fully inflated.
I also threw together and extra front beam I had around the garage. Going to try to get it installed and get the Sled on the ground for the first time in several years.
May 28th, 2012, 04:24 AM
#1364
Re: Type 3 VolksRod
Just make the fenders easily removable so you can change the tire if need be.
May 28th, 2012, 08:24 AM
#1365
Re: Type 3 VolksRod
If you were worried about ease of tire changes you would have left it stock
I don't want to jinx myself but I don't remember the last time I had a flat tire.
May 28th, 2012, 09:15 AM
#1366
Re: Type 3 VolksRod
I don't think tight is the word
Git-r-dun JOHN!
May 28th, 2012, 05:44 PM
#1367
Re: Type 3 VolksRod
There have been countless reasons why I have had to pull the wheels off. Just getting a jack under the volkster is enough a challenge!
July 2nd, 2012, 05:15 PM
#1368
Re: Type 3 VolksRod
Any new pics?
July 2nd, 2012, 07:10 PM
#1369
Re: Type 3 VolksRod
Originally Posted by Flipper_1938
Any new pics?
Not yet. Been too busy getting Jill's Ghia ready for the show season and the trip to Colorado Springs (which she wasn't able to take due to some surgery), getting Sophy ready for and taking her on the Invasion trip to Colorado Springs. In Minnesota right now for a vacation and working on our cabin.
I will get back to the Sled later this month when we are back.
Slow steady progress....
July 2nd, 2012, 08:56 PM
#1370
Re: Type 3 VolksRod
Alright buddy... enjoy the time at the cabin and get some rest! Oh, and avoid the freaking heat!
August 19th, 2012, 06:13 PM
#1371
Re: Type 3 VolksRod
Don't want the Sled to end up in the "Old Projects" thread, so I figured I better get out there this weekend and do something to progress her.
I had previously installed the rear subframe with the new air-ride mounts and some solid wooden blocks to represent the airbags at ride height. I installed a mock-up front end so I could put it back on the ground for the first time in years. Then I rolled it out onto the driveway for a few beauty shots...
Of course, I had to do a little PhotoShop work to get rid of the nosebleed stance....
With the front end back in, I decided it would be good to have the steering column back in to make moving her around easier.
Started out by bolting the column in without the ignition switch/turn signal housing. Also bolted in the driver's seat to make sure the steering wheel position was OK. After mocking it up, I decided to line the steering wheel up with the centerline of my eyesight instead of the cutout from the Rambler dash.
I needed to enlarge the cut-out anyway to fit the ignition switch housing so it wasn't any more work to get it where I wanted. So after some cutting and fitting This is what I ended up with...
I had to put a small depression on the left side to clear the turn signal switch. I also have some more clearancing to do around the ignition switch and then I need to weld some sheetmetal to finish off the new cut-out.
Close-up of the clearancing for the turn signal switch....
Close-up of the clearancing for the ignition switch...
And a shot with a steering wheel in place...
Still need to fabricate the column hanging bracket that the ignition switch housing bolts to and finish off the inside of the cut-out, but it looks like it is all going to work out good.
August 19th, 2012, 06:16 PM
#1372
Re: Type 3 VolksRod
Oh yeah....the rear airbag mounts appear to be fine. Plenty strong.
August 19th, 2012, 06:21 PM
#1373
Re: Type 3 VolksRod
What a pile!!!
Love ya John!
August 19th, 2012, 06:28 PM
#1374
Re: Type 3 VolksRod
August 19th, 2012, 07:35 PM
#1375
Re: Type 3 VolksRod
SWEET.
| Thread Tools |
| Display Modes |
